Window motor wiring
Having difficulty finding where the window motor wires connect on the motor. I've got access to the motor and regulator, but I can't see well enough inside the door compartment to see where or how they connect. Any directions or especially pictures would be greatly appreciated. 1986 911 targa. Thanks
Old 05-03-2016, 09:28 AM
83 911SC Cab
Cherry Bomb's Avatar
hoping this helps....
Old 05-03-2016, 09:35 AM
So the two yellow connectors are where the two wires connect from the switch to the motor? Sorry I'm new to this procedure. Thanks for the pictures. I'm assuming I remove the two wires at that connection and then I can remove the window motor and regulator??
Old 05-03-2016, 10:21 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Motor.
Are trying to remove the motor?
Or, just the wires?
You can remove the motor without removing the regulator.
pm me as needed.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-03-2016, 10:41 AM
I tried to send you a pm. Guess I don't know what I'm doing there also. Haha. Yes I'm just trying to replace my window motor only. I thought the regulator comes out along with the motor?????? Thanks for your replies
Old 05-03-2016, 11:30 AM
sky1jord's Avatar
Gerry
True, but IIRC, you'll still have to detach the regulator from the door to get the motor into a position where it can be unscrewed from the regulator arm.
Also, I was lucky enough to have a switch-to-motor cable that had a 2-terminal connector to mate at the motor end, making it much easier to make a connection than dealing with two independent faston tabs.
Good Luck
Old 05-03-2016, 11:32 AM
sky1jord's Avatar
This should give you further help.
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 05-03-2016, 11:36 AM
Thanks to Gerry and sky for there advice. I finally got the motor out without removing the regulator. Mine also has a a two cable connector. Can either of you please tell me where I can/should purchase a new motor. Was thinking about a used replacement, but don't want to trust the condition and I'm also not too eager to do this job again anytime soon. Any feedback is always appreciated. Thanks again. Gary
Old 05-03-2016, 06:18 PM
