Should I hear the fuel pump run at pre-crank position?
Car is a 1984 Turbo Look Coupe, 3.2
I can hear fuel pump run when I jump the fuse, but not at pre-crank. It could be that it is not a very loud pump. I have a 1973 914/2.0 and I can easily hear fuel pump. I am having a problem with the 911 starting consistently and am trying to diagnose. I don't like to diagnose through replacement.
Old 04-29-2016, 07:35 AM
prschmn's Avatar
3.2s only run the pump at start position or when there's a tach signal-I.E. running
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 04-29-2016, 07:56 AM
Vintage Motorsport
RichardNew's Avatar
Rather than buy a new pump you can have the original pump rebuilt. A lot of use here have used Fuel Injection Corp and had really good experiences.
Richard Newton
Car Problems and a Few Solutions
Old 04-29-2016, 08:00 AM
Thanks guys.
Old 05-04-2016, 10:39 AM
Member 911 Anonymous
DRACO A5OG's Avatar
What timing!
I just called FIC, $20 to test and $118 to rebuild.
My brand new OEM from dealer pump started to buzz after 2 years, yes after the warranty.
I am sending mine to them and send my old OEM one right after that.
Thanks Brother RichardNew
'85 Carrera Targa
PCA/POC
Old 05-04-2016, 11:08 AM
i cant comment on a 3.2 exactly, but thats the purpose of the fuel pump relay, so for an SC the pump only runs at crank or when the air flap moves (engine running), so you'll never hear the fuel pump because of all of the other noises. It sounds like a 3.2 is the same but works differently
your 73 914, and my 73 911, dont have fuel pump relays, so when you turn the ignition on hear it come on, as its a direct switch from the ignition.
Old 05-04-2016, 01:29 PM
steely's Avatar
You should not hear the fuel pump until you crank the starter.
Here's a helpful thread - oops, it's yours!
1984 3.2 starting problems
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-04-2016, 03:30 PM
FIC rebuilt my pumps for me Pumpkin. Very satisfied!! I got a discount, I had 2
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 05-04-2016, 07:46 PM
