Aluminum Pressure Plate Rebuild
If anyone has done this, what do you get done?
I was going to change the fulcrum - I think it it basically a spacer. Anything else done to make these stronger? |
Member 911 Anonymous
Hmmm, I thought once it lost it's tensil strength, it is time to replace it, no?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Schleprock
Ask Dick Shift here if he can share some of his machining tricks. He cuts the housing surface and the pressure plate/friction surface a certain amount to regain some clamping force.
Kevin L '86 Carrera "Larry" |
Thanks Kevin.
Perhaps I will pm him about thread. |
