Battery size and mounting- pictures please
I've been looking for an alternative battery and mount , I see rennline do an aluminium cradle.
My cables are very tight with the inner wing,
My thinking was a smaller battery centred in the original tray, maybe on a mount.
Let's see some pictures of what options there is?
Old 05-30-2016, 10:52 AM
steely's Avatar
I did this with an Optima - pictures aren't mine.
Optima power!
I also upgraded the ground for more slack.
Do a search, some have mounted one in the smugglers box - some assembly required.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-30-2016, 02:58 PM
6 cylinder symphony
I run an optima red-top. Have for years.
Purchased the Optima mounting plate sold on this site. That's what it sits on, secured by the stock mounting tabs.
Do a search - I seem to remember someone building a mount out of a plastic cutting board, so they could use the stock mounting tabs.
Edit: yeah - it's currently 5 threads below - another battery install thread
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 05-30-2016, 03:17 PM
Banned
juanbenae's Avatar
you can go to tap plastics or the like and get a base the size of the OE battery mount tabs out of a material like the plastic cutting boards. a 1/2" should suffice. then mount your yellow or red top type battery to it, then it to the OE mounting tabs. done, $30 max with the assorted hardware to mount the battery.
Old 05-30-2016, 05:29 PM
gliding_serpent's Avatar
For Canadian folks, turns out Canadian Tire has lots of Powersports AGM batteries... all their Motormaster house brand, but the prices were good, and they were compact. Very compact. Holy crap these things are shockingly small. My original battery that left me stranded on track could probably fit five of these little bad boys inside. I could not find great specs on my battery, but it is a Morotmaster Eliminator Ultra AGM Powersports Battery. Size 20L-BS, model number 027-1037. 12V, 18 Ah capacity (10hr), 270 cold cranking amps (0 degrees C), and it feels to be around 15 lbs.
Cutting board modified for the smaller battery. I know this is a bit ghetto, but it has not moved a bit, and the thing had run like a top. Just note that these small batteries need frequent use, or to be put on a trickle charger.
Saves about 30lbs!!!
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 05-30-2016, 06:22 PM
that cargo ratchet is ridiculous. Why don't you get get a plastic buckle that snaps together? I got one on eBay for a few bucks and some webbing.
That way it does not look like a tie down in the back of a pickup.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-30-2016, 07:58 PM
What's wrong with the pick up look Dick? Some of us use them as daily drivers.
84 911 Targa Carrera currently getting renewed
Old 05-30-2016, 08:16 PM
jdbunda's Avatar
I did a similar thing with a Duracell powersports battery I got from Batteries plus, thread is here.
Yet another early car battery option - Duracell?
Instead of the big ratchet tie-down, I went slightly less shade-tree with zip ties.
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 05-31-2016, 02:37 PM
Zip tie is way too elitist for me guys. Would you like some wine with that zip tie cheese?
The wratchet allowed me to stap the puppy down so tight it said unkle.
Old 05-31-2016, 02:44 PM
I also have a plastic buckle, take a look... Double pow!!!
Old 05-31-2016, 02:45 PM
jdbunda's Avatar
Where did you source the correct green webbing? I used zip ties because I couldn't find yellow zinc plated bungie hooks.
John
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 05-31-2016, 05:31 PM
I have a PU.
03 Boxster
Old 05-31-2016, 06:13 PM
steely's Avatar
Shockingly small to say the least! - Why there's more terminal post than battery -pretty neat.
What kind of cheese?
Dan
Venetian Blue
Old 05-31-2016, 06:28 PM
The green webbing is NLA from porsche. Rumor has it, ferry porsche used the same ratchet part with green webbing for his infamous 1973 911 carrera rs that had 3 class wins. It is probably worth an easy 1k on the marketplace.
P.s.: people, please stop ****ing messaging me with low ball offers for my historically significant battery ratchet with green webbing. No tire kicking. This is true history, and I will entertain serious buyers only.
1973 BMW 2002Tii
2016 Ford Focus RS
Old 06-02-2016, 07:30 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Just think, G.S., if you ever need to lift the front of your car with an engine hoist, you can just hook on to that motorcycle tie down strap (probably need to counterweight the other side of the car for leveling purposes, buttofcourse)!
Old 06-02-2016, 07:37 PM
My question is why are motorcycle owners usin vintage 911 rs battery ratchets??? Don't they know how expensive/valuable/rare they are?
1973 BMW 2002Tii
2016 Ford Focus RS
Old 06-03-2016, 04:14 AM
RS correct Green strapping or not.....shouldn't it be installed the other direction to move the batter weight as far forward as possible for better handling?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 06-03-2016, 04:40 AM
Well played, guys. I laughed.
Matt - 84 Carrera
Old 06-03-2016, 07:03 AM
Yes, but what about polar moment of inertia? It is a trade-off. In the end i stuck with Ferry Porsche and kept things in the stock location (and stock cutting board for mounting) used in the 3 time class winning Rs. In reality, having the ratchet pointed in the other direction would be more ideal than my current setup as the buckle is asymmetrical in shape, thus effecting corner balancing in a negative way. It may not seem like much, but it all adds up. That is why the fuchs cap logos need to be lined up... If they are not you can actually throw off wheel balance from right to left due to weight differences from the engraving. The spinning action actually accentuates the imbalance and there have been a few reports of fuchs wheels falling off at speed due to the phenomenon. do a forum search on the topic... it is pretty scary. The concourse guys had it right. This is why bmw opted for a symmetrical logo... Problem solved!!!
1973 BMW 2002Tii
2016 Ford Focus RS
Old 06-03-2016, 09:09 AM
Cheese wiz.
1973 BMW 2002Tii
2016 Ford Focus RS
Old 06-03-2016, 01:05 PM
