Unable to align/assemble Cat Bypass
Hello all.
My first post here, hope it's in the right spot.
I am in the process of replacing my Catalytic converter with a Cat bypass. This unit was previously installed (and later removed) by the previous owner. I have the engine side of the bypass attached, bolts still loose. I am unable to mate the muffler because of bypass misalignment to the outboard side 1". I loosened the muffler clamps and have about 1/2" of misalignment remaining. Wondering if the primary/secondary muffler is on a slotted mount to allow for further adjustment?
Any input would be greatly appreciated.
1991 C2. Bone stock condition.
Old 05-11-2016, 12:22 AM
Ramp's Avatar
I had to loosen the exhaust manifold and jiggle to get the alignment set up. I didn't need to touch the muffler.
'86.5 Porsche 928S
'87 Porsche 3.2 Cab
'12 Jaguar XJ
'14 Mercedes GL550
'16 Mercedes C300
Old 05-11-2016, 03:58 AM
Figured it out!!!!! The inner heat shield was just a hair to wide from centerline. This prevented the Bypass from fitting properly. Since the Bypass runs cooler than a Cat, there is no heat risk to surrounding structure, I removed the shield. I am amazed at the improvement in sound and a noticeable difference in performance!!!!
Old 05-14-2016, 09:05 PM
