jueyero
Question Problem with transmission parts need help
I bought the 3,4 and the 5th dog teeth part #90130224203 when I received is not the same one for mine a 915/61, se pictures attached is a modification or I got the wrong ones need help
Old 05-15-2016, 06:22 AM
gearhead
Is it bigger? Did you get a 915 2gear set of teeth?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-15-2016, 06:28 AM
If it's the same diameter, it's the right part. 3/4/5 are all the same. What do you think is different?
206 637 4071
jueyero
the problem is right on the opening part one has like indent, next use one is flat on the opening and the new ones are different on the opennings
Old 05-15-2016, 06:32 AM
jueyero
this is the other one
Old 05-15-2016, 06:33 AM
No problemo.
206 637 4071
Old 05-15-2016, 06:41 AM
jueyero
matt and john, also I got a problem with the bell housing mean by this is the part facing the engine the bearing for the shaft , the races are easily remove and I saw videos posted that the housing is no good
Old 05-15-2016, 06:48 AM
jueyero
no problem means I can use
Old 05-15-2016, 06:51 AM
That's a problem. See the third item. PORSCHE 915 TRANSMISSION – California Motorsports Inc
I'm sure there are other places that do this.
206 637 4071
Old 05-15-2016, 08:24 AM
