Expansion valve.
I have done a search on the forum but but I cannot find much of replacing the expansion valve on a 3.2 car. Is it possible to replace the valve from the smugglers box? I can see it in the box and it is covered with tar. Thank you.
Member 911 Anonymous
Yes, just make certain you have the proper sized o rings.
Also may want to consider replacing the dryer as well. Pull and hold a vacuum then refill with refrigerant of choice.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks Jim!
Fleabit peanut monkey
Tar is called Prestite tape or something close to that.
Should be available locally at a NAPA store. Might have to wait a day to get it.
1981 911SC Targa |
Nick,
If you research you might find some valves come with new o-rings, prestite, bulb clip and some installation support. Be cautions on what valve you buy, some are marketing valves that have the sensing bulb tube coming straight up rather than out flat off the top of the valve; the wrong one will make it difficult to close the smuggler's box lid.
Kuehl 1987 911 cab, modified https://griffiths.com/ |
I got a roll of the prestite tape locally at an A/C supply house (something that is every 2 blocks here in Houston...). They called it cork tape. Enough on one roll to last 15 cars, about $15.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Nick,
Mike said he is going ship you some prestite Bob is bringing the beer
Be sure you don't infringe on what's-his-names patents
You guys kill me
Thanks everyone!
Mighty Meatlocker Turbo
Bob will bring the beer, but use caution when reaching for one if he is nearby when you do (might lose a finger, otherwise)! Are you going to reverse the methane, too?!?!? |
Immature Member
It's worth having a Porsche just for the AC threads. Great entertainment value!
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Unless Bob brings enough beer, then we'll start producing it!
Gives new meaning to the term "expansion valve"!!!
