This sounds like heavy money to me Casey. Even in the metro NY area, top end engine rebuilds at very reputable shops are less than $15k, assuming all the normal issues are addressed. http://financeseeyou.com/red/images/7.gif
http://financeseeyou.com/red/images/8.gif http://financeseeyou.com/red/images/51.gif |
Don:
Reading this thread again, I see two underlying issues -- 1) your external oil leaks and 2) whether you have an underlying oil consumption issue. My '86 carrera needed to have its valve guides replaced at around 90k miles due to my oil consumption hitting around 500 miles per quart. I was seeing rather significant dripping at the time and asked my mechanic how much of my consumption I should contribute to the dripping. He measured out a teaspoon of oil and dropped it on the floor -- it left a surprisingly large puddle -- and advised me that my oil leaks were having, at best, a nominal impact on my overall oil consumption. SO, in my case, the oil was being sucked into the cyliniders via the worn valve guides and both my oil leaks and oil consumption problems were resolved through a top end overhaul. Not clear from your posts what your underlying oil consumption is looking like (or what your plugs look like, etc.) ? Seems like you'd be "spinning wheels" and potentially wasting time/money if you put the time and effort into chasing external leaks with the engine in the car, only to later determine that it really needs an engine drop/top end overhaul. |
Since I'm in sort of a similar situation as the OP I thought I'd add a little "from my perspective" commentary.
My car is an `87 Carrera, I started realizing I had the premature valve guide issue at ~35K miles. I now have 99K, I have minor oil leaking and my usage is < 1 quart per 500 miles. Since the question of fouled plugs came up and I just replace mine last weekend I thought I post a picture of my plugs after > 10K miles. I only see excessive carbon build up on plug #5 the others run pretty clean. The car still runs very strong no missing. And yes I stick them in a piece of cardboard each time, I toss them once I've eyeballed them sufficiently. My reason for such interest in this thread is I'm in that boat too. http://forums.pelicanparts.com/uploa...1463688292.jpg |
jwill -- your plug #5 looks VERY familiar -- Good news is that you should be fine for a LONG time once you get the top end done -- I've got 90k on my top end rebuild (171k total) and am getting around 1,500 miles per quart (with some relatively significant leakage now occurring too)
Triangle of death.
I removed the air cleaner/air meter as one assy.
Then the fuel meter. At that point you have good access the "Triangle". But, prior to doing that, clean up the motor, and, using a mirror, let's see, if the leak is @ the triangle. http://forums.pelicanparts.com/uploa...1463700054.jpg http://forums.pelicanparts.com/uploa...1463700085.jpg http://forums.pelicanparts.com/uploa...1463700121.jpg http://forums.pelicanparts.com/uploa...1463700539.jpg ^^^^^ Here are the locations. I would suggest cleaning up the motor, then, have a look. You can't fix what you can't see............ I had a leak at the oil pressure switch which sent the oil to all "corners" of the motor. "While I was in there" I replaced all of the "local" gaskets. Parts are cheap, about two hours time. Good luck, Gerry pm me as needed[/QUOTE] |
Oil leaks.
Have a look at my post on this thread. Gerry |
Oil leaks.
Gerry |
I've replaced the blower motor when it died, so I'm familiar with the time/effort to R&R it, and I had the air filter box off when I R&R'd the sound padding, so that'd be a relatively easy not-so instant replay as well. I thought about removing the air flow and fuel meter assemblies as well at the time, but found that it wasn't all that necessary to accomplish my task, so I didn't mess with them. Now it doesn't seem so daunting... a PIA for sure, but at least a manageable one. I also see that your engine/xmission were out of the vehicle, which obviously would render the task to be f-a-r simpler, so I've got a bit of work/reward concerns to weigh on a personal level. As you noted, clean it first... can't fix what you can't see. Thanks again! Don (PS... Dang, I miss the old Manhattan Bar and Grill on MBBlvd near Sepulveda) |
| All times are GMT -8. The time now is 12:06 PM. |
