That's fond- just deglaze
What is it? Where does it go?
She is a 1986 3.2 Coupe w/ factory alarm- I removed the door panel to clean & lube the passenger side door latch/lock/springs/etc. (Note: the original vapor barrier was still in place!) and this was laying in the bottom of the inner door. I have reviewed the '86 exploded parts schematic and I cannot find a match anywhere. It is appx. 1/2 inch in height, non-ferrous (non-magnetic) and heavy. I suspect it is lead. Where does it go?
Old 05-19-2016, 07:59 PM
ROW '78 911 Targa
timmy2's Avatar
Spring retainer pin on window winder assembly.
Do a search, fairly common to fall out and need replacement.
Pelican sells them.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-19-2016, 08:05 PM
Thank you Dennis!!! Found all the data- ordering from our host!
Old 05-19-2016, 08:18 PM
