1979 930 @outlaw3.4
Chasing tail lights - right side-
My rear right side tail lights are not working- but I am power to the gray wire with red stripe when I pull the light switch. The blinker works, brake lights the reverse light works and the hazard lights are good- but just not the tail lights, the bulb elements are good too.....
out of the same multi pin plug is the oil level sending unit that is also not working ( unit works when I run a wire direct- ) Which wire powers the tail lights? Here are the pictures - ![]() ![]()
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Light.
![]() ^^^^^ Here is the factory wiring for our '86. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Oil level sender.
![]() ^^^^^ Not related to your taillight CKT. Good luck, Gerry
Put a test light on it and find out.
1979 930 @outlaw3.4
Bulb not seating on the tabs!
I think I found the problem - tabs were bent in and bulb not hitting on one - naturally broke the clip on the housing - so been epoxing all afternoon- but hopefully that is solved.
Leaves me with sending unit wire - still not sure where the break is...i know it is one of the 8 pins above tail light. I guess I need to take the shearing back and look for the red yellow wire.. Thanks for posting - I commented before hitting refresh. The test light showed power to the tabs....I will check where the bulb makes contact. I am questing it will have power, Thanks again Last edited by MZ3 SBC; 05-21-2016 at 05:56 PM.. |
1979 930 @outlaw3.4
Problem fixed
It was the tab -
Now to trace the oil sender line - appears to be green/ black from gauge to connector plug above tail light Love making progress - even if it's one wire at a time |
1979 930 @outlaw3.4
I found the oil sending gauge issue -
There was a break in the hot wire that gOes from gauge to sending unit. I found the break accused somewhere between the 8 pin connector and the sending unit.
The hot wire is green with a white stripe form gauge and it runs that way all the way to the connector above the right tail ligh, after the connector there is a yellow and red wire to sending unit, Jumping the connector plug as seen in the photo- gauge is working! Hope this helps someone in the future.....
