rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Driver's Door Lock & Window Switch Questions 911 SC
Recently, my driver side door lock was spinning freely when I turned the key. I removed the door handle and discovered that the screw that holds the lock in was loose, so I tightened it, reinstalled the handle, and closed up the interior door panel.
When I tried to lock the car, the key wouldn't turn, so I took the interior panel off and took the picture below. Is the rabbit ear actuator (for want of a better term) in the correct position vis a vis the bar coming off the lock. What am I doing wrong?
Also, does anyone have a good picture of the wire connections for the passenger door switch that is in the driver's door? I seem to not have that right either.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 05-26-2016, 04:39 PM
rs6er's Avatar
Actually, I just tried the door lock, and it's working properly.
So I only need an answer to the question about the window switch wiring.
John
Old 05-26-2016, 04:53 PM
