Engine leak sealer
OK folks, I know everybody hates the pour in additive
To seal engine leaks but does anyone have any first hand experience as to if the additives work and engine leaks or are they just introducing more problems? Thanks for the feedback |
Member 911 Anonymous
Don't do it and don't use an engine oil flush either, you will regret it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-24-2016 at 09:35 PM.. |
Reiver
No, don't.
If there are any particles/grunge in your oil passage lines any 'sealant' will tend to build up in that area too possibly blocking off or restricting your oil flow. Not a good thing. Quick fix's have numerous negative issues much like the fine print on drugs...may cause greasy flatulence...or death.
De Oppresso Liber Strength and Honor 5th Legion |
My other ride is a C-130J
I by no means am an expert but three questions come to mind.
1) Where are you leaking oil from? 2) How much is leaking? And 3) What type of oil are you using? Naturally some oil leaks are addressed by replacing gaskets, seals, warped covers etc . . . In my case, driving the car more frequently and changing the oil to Brad Penn (and later Shell Rotella) drastically reduced the amount of oil I would drip. Personal discussions I've had with engine rebuilders have steered me away from ever introducing those additives to my system for reasons outlined above. Good Luck
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
As other said don't do it. You can use heavier oil if you are burning it till you can do a refresh. I used to run strait 50wt oil in my old vw bus to slow the consumption. If you have a old tired motor NEVER put synthetic in it. It will eventually find its way out and start new leaks.
Good luck and remember that these are very expensive motors and using cheap tricks usually don't work and could cost you more in the end.
1982 SC "Spooky" 1961 VW Single cab truck 1966 VW Deluxe Hard top |
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
