walt's Avatar
Main Pulley Bolt Removal
The engine is out of the car with the transmission attached. I have tried to remove this nut with a 1/2 drive impact wrench without success. Also tried a breaker bar with a strap wrench around the pulley - no good either.
Any options other than removing the transmission and locking down the flywheel.
Thanks,
Walt
82SC 3.0
81SC 3.6
Old 06-06-2017, 02:44 PM
Which 1/2 inch drive impact gun and what was the air PSI ?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-06-2017, 03:05 PM
walt's Avatar
Unfortunately it's electric. My air compressor isn't large enough to handle an air wrench.
Walt
82SC 3.0
81SC 3.6
Old 06-06-2017, 04:07 PM
Heat the bolt hot enough to melt the loctite, then hit it with impact.
Bruce
Old 06-06-2017, 04:30 PM
TibetanT's Avatar
Walt:
Does your car have A/C ? Because if it does, that bolt is torqued at around 150 ft lbs.
Good luck
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 06-06-2017, 04:38 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Lock your flywheel and use a breaker bar
'85 Carrera Targa
PCA/POC
Old 06-06-2017, 09:33 PM
He was trying to not remove the transmission so ....
My trusty Ingersol Rand 1/2 impact wrench at 125 psi has never let me down.
Short of that, I think remove the starter and jam something into the gear. Although, I don't think it works as well as removing the gear box. It is really not that hard.
Old 06-07-2017, 07:13 AM
theiceman's Avatar
put it in gear and lock a driveshaft flange ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-07-2017, 07:26 AM
Between the time of trying two different techniques, posting here and waiting for an answer, you could have pulled the tranny, locked the flywheel with a short wrench, cracked the bold loose and put the tranny back on...
Just sayin...
Since the tranny is still mounted, is the starter there as well? Put breaker bar on bolt, prop end of breaker bar against floor, bump starter with jumper cables to battery for 1 second.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 06-07-2017, 07:50 AM
I think this is dangerous ...
I had a very close call last week. Really very lucky.
Old 06-07-2017, 08:36 AM
theiceman's Avatar
Just sayin...
OP puts breaker bar on wrong side , hits starter with juice and knocks himself out cold with breaker bar ..
Old 06-07-2017, 09:40 AM
walt's Avatar
Got the head of the bolt cherry red and it broke loose. I forget that heat is your friend.
Thanks Bruce.
Walt
Walt
82SC 3.0
81SC 3.6
Old 06-07-2017, 12:58 PM
