77 911 different height rear
My 1977 911 sits about 1/2 inch lower on drivers side rear. Front height is equal on both sides. What do you suggest to fix this?
Thanks. |
Raise the driver's side rear?
Matt - 84 Carrera |
Or lowering the passenger side 0,5 ". Will this mean that the swing arm must be remowed from the car?
Registered Minimalist
Sort of. You don't technically remove them from the car (I mean you can, but you don't have to remove the torsion bar covers or trim), the spring plates come off the torsion bar and can hang off the end while you re-index them. You re-index the spring plate on the inner or outter torsion bar spline. If your spring plates are like mine, you don't have the height adjustment bolts like the SC and on. If you are mechanically inclined you can follow the procedure in the Haynes manual, or as outlined in numerous threads on this board.
You can see how I did it here. I have the same problem as you. It's probably because one side is on a different spline on the torsion bar. Also, the front on opposite corners can affect the rear height. So lowering the front right would raise the rear left slightly.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 05-24-2016 at 06:42 AM.. |
Thanks 75 911, this is just what I needed.
If your '77 is like my '77 then you can make minor adjustments to ride height similar to an SC with no need to re-index.
OK, thanks. So what way shall I turn the eccentric bolt to lower the car?
depends on where it's set currently I guess. a magnetic angle finder is an important tool in this endeavor.
I would rather be driving
Was the car corner balanced? If so, the ride heights may be different for a reason. A level setting for suspension corner weights does not always equal a level ride height.
Think before you turn wrenches or you may sacrifice handling quality.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Member 911 Anonymous
Fellas, I hate to rain on your parade. but if OP lowers the one side it will inversely affect the other corner and partly the perpendicular corners.
OP. I suggest you go to a reputable alignment shop, corner balance with you in the car, have a big smile on your face on corners and live with the lovely cocked eyed fender heights or drive yourself crazy trying to straighten out the fenders. You will get close but not spot on unfortunately. In fact try having a helper measure the heights while you are in the car. You will absolutely go cookoo. Apparently the Engineers at PAG did not like the Body Designers back in the day. Thank goodness for modern CAD aided autobots.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
^^^^ this. I had my car's suspension tuned by Rothsport. It came back with a 1/2 inch list but the corner weights were dead on. Couldn't be happier with the handling.
