Front struts
At slow speeds ( idle rolling ) a metal to metal bumping .... while stopped and pushing the front up and down I sound like from the insert from the front shock is this a good indication it is time for a new one or can it be tightened up ... I have read the procedure for the replacement and if this is the case should it be attempted as a diy project with the wheel alignment that will now be required ... thanks for any advise
Old 07-18-2017, 06:37 PM
Administrator
Dmitry at Pelican Parts's Avatar
Sounds like it's time for an upgrade; the metal on metal bumping that's happening; have you looked at the bushings as well?
Old 07-19-2017, 11:56 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
If you have Bilsteins, you can pull them out and just replace the inserts. I don't think this will impact the alignment.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 07-19-2017, 12:24 PM
Under the radar
Trackrash's Avatar
Could just be a loose insert. The nut at the top that holds the insert in has been known to come loose.
Or the the bushings and shocks could be worn out. Lots of threads on this same subject.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-19-2017, 02:38 PM
Could it be a broken roll pin maybe it was installed incorrectly by a PO?
1982 911 Targa, 3.0L ROW with Webers
Old 07-19-2017, 03:00 PM
Thanks gentlemen .... I will be looking a little closer into those insert replacement procedures once I get them on order from the host...
Old 07-19-2017, 05:18 PM
I just did this, one tool that made the job so easy was a special roll pin punch. Get one for around $10 on amazon. I did one side with and one side with out and I can tell you it makes a world of difference.
https://www.amazon.com/gp/aw/d/B008M22GJ6/ref=sr_ph_1?ie=UTF8&qid=1500510825&sr=sr-1&pi=AC_SX236_SY340_QL65&keywords=Mayhew+Pro+25027+7mm+Pilot+Punch
Old 07-19-2017, 05:34 PM
