Member 911 Anonymous
84-88, or just 3.2's
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Dial 911
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
Dial 911
While waiting to receive an Alarm Module replacement, last night I made a new post under the heading of; Need assisatance in Vancouver (BC) asking if there was any Pelican in my area that would be willing to let me check my ECU out on their 3.2's As a matter of interest, would I be able to do the test on all years of 911 3.2's or just specific years? A Bud on mine has told me that all years will work. I do believe him ...But then ~ 'You're de man' ![]() Thanks!
Re-read your initial post:
problem was the alarm ECU, but after all the parts changing another problem was caused. Your posts indicate that you have not followed through with all the recommended testing, i.e. checking for an injector pulse which would help localizing the problem to the DME ECU or not. Also, the fuel pump relay (stage 1 of DME relay) should activate while cranking and cause the FP to run. This also probably has not been checked. Maybe at this point you need to have the Porsche taken to a capable Porsche repair shop for a proper diagnosis and not waste additional time and money, which has probably been the case.
Dave Last edited by mysocal911; 06-22-2016 at 07:06 PM.. |
In addition in your case either swapping you DME into another car or swapping a good DME into yours is fine As a matter of fact I have sent my loaner out several times for folks to do just that in 'stubborn' cases. Good luck, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Dial 911
Could this be it?
Being that I'm waiting to check my ECU out with a hospitable local Pelicans car on Saturday morning, I went about rechecked a few items today. When I had checked the coil a few days ago, prior to finding the power issue, the coil was OK.
Today I found that the coil's Primary Resistance to be 4.9? It's supposed to between .4 and .7 ohm. On a plug wire that would be what I would call an 'open wire'...It appears that the coil has had it. The Secondary Resistance of 5.60 is within the spec's of between 5.0 - 8.7 kohms. It's the original coil. Being that Bosch coils that are manufactured in Brazil have such bad reviews from other Pelicans, what are the alternatives?
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 06-25-2016 at 09:24 PM.. Reason: change of info + question |
Dial 911
I recently returned from a local Pelicans home, 'Hendog -aka- Henri, who had replied to my post for someone with a 3.2 to test my ECU out...He was not only generous in his offer to do so, but when my ECU failed to start his car, he then kindly asked me if I would mind him having a look at it.
Henri's idea of 'having a look at it' was a major resoldering of the board! When doing so, he also found that one of the rear pins,#1, out of the 35 pin section, was loose...Yes!..Heni then resoldered the pin, reinstalled the board into it's box, popped it into his beautiful, low km '87 Venetian blue Carrera Coupe, that has SSI Headers, muffler, SW chipped with Custom Porsche three piece wheels and up it fired! My 'no start' issue look's like it's 'finally' coming to an end... What was discovered during the week: 1. Dirty contact-points in the alarm module, when cleaned, restored the power to both the DME 35 pin connector and relay, due to a suggestion from '96 911 Targa' 2. After doing doing one more recheck, out of numerous 're-checks that were mainly suggestions from both "Ingo' and '96 911 Targa', I found out that the ignition coil was now toast! I had checked it out previously and found it to be OK. 3. While waiting for an alarm module to arrive, I thought that it would be best to see if I could find a Pelican who would check my ECU out -Draco's suggestion - Walla! As Jim recently stated, quote: "I just love this Pelican Board!" ...That I whole heartly second! I not only had a local Pelican test and repair my DME, but most importantly, I was able to meet one heck of a congenial, 'can't do enough for you' guy. I'm now going to purchase a new coil, replace the alarm module, and once these are installed, I'm now quite sure that 'The Phoenix' will rise from its ashes' ![]() Hat's off to 'Hendog! ![]() Thanks so much 'Henri...Much appreciated!
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 06-26-2016 at 12:49 AM.. Reason: Coil Info Correction |
Dial 911
Hendog 'just' having a look at it
Glad it's working. But please let's be 100% clear and not spread wrong information for others:
1. The coil is not being burned out when leaving the ignition on for extended times. That's physically impossible with a DME unless your interior of the DME is charred like in this example below: ![]() Here the ignition driver shorted and subjected the coil to full power and in the process it burned the current shunt. BTW, this was repaired and the DME is working ever since. 2. If a pin "is lose" on the EPROM and it's causing an issue the ICV will not vibrate. Again physically impossible.: If the ICV vibrates the the DME is executing code from the EPROM (chip) and it is ok. Ingo
Dial 911
Thanks again Ingo...I'll edit my coil info.
'Hendog' found that the #1 pin, of a section of 24 pins, failed a continuity check after finding that it was loose. He soldered in another very small piece of wire as it was actually broken within its plastic insulation. (Btw, he is an electrical technician) Correction: 'Hendog' repaired #1 pin of the 34 pin main ECU connection section. Re the coil. I know that the older cars without a PCM, by leaving the ignition on, you could burn the points out. As a matter of interest, have you any idea why the coil went when only days earlier it was OK?...Was it just a coincidence or did I somehow short something out? Thanks.
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 06-25-2016 at 09:43 PM.. Reason: Correction of repair section |
![]() I'm not sure if 4.9 Ohms is fatal to a coil? I suppose if it should be .4 to .7 then it is rather high, but would that cause a no start condition?
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Dial 911
I had phoned an auto electrical shop yesterday to ask them if a reading like that meant that the coil was gone, and they had replied that 'yes it would'. I'll let you know in a few minutes.
Whoa
Above and Beyond!
Oh! 4.9Kohm! I misread it as 4.9 ohms. Big difference... Then I suppose that is bad for sure.
Hopefully!
Dave |
in the ECU which may manifest itself later.
Dave |
Dial 911
![]() No more "Sleepless in Vancouver" - Happiness is seeing the German windmill spin again!
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 06-26-2016 at 01:43 AM.. |
A reading of 4.9 Ohm could be a measurement error. Depending on quality of the meter, cleanliness of the test leads etc. you quickly make errors in the low ohm range. It's hard to imagine how a primary fails with that kind of reading, just saying....
I assume it started on this coil, correct? Ingo
Excellent!!
HURRAY!! So glad to hear it started!
Ischmidt is right; 4.9 Ohms is so close to a short it was likely just a poor contact of your probes or any number of things if it was indeed 4.9 and not 4.9k YEAY!!!
Dial 911
Muitimeters: I had one of OTC's higher end multimeter for decades (is that possible-> higher end )... I have had a 177 Fluke for a couple of years now.This time around, I measured the coils Primary and Secondary resistance three to four times, and I consistently got the same readings. If anything, maybe my first readings were incorrect ay. For preventive maintenance, I'm going to replace the coil anyway, as it appears that it may be on it's way out. Ingo...I'm 'not so sorry' that I now don't have to send you my ECU to be refurbished Thanks again for all of your input. Much appreciated!
