Holy Cap: What's the trick for Dist Cap?
Hi Pelicans,
I have an 86 coupe, and this morning I decided to tackle the spark plugs cap and rotor. Using the Hazet tool and a short handled ratchet, the spark plugs were EASY (thanks Pelicans), but more on that later. I thought I was at the easy part when I got to the distributor cap but: I can't remove the plugs from the top of the cap to save my life. I've tried bare hands, I've tried gloves, I've tried pliers with a rag wrapped around them. I'm afraid of breaking something. Any tips? Thanks. Martin |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Are you referring to the rubber insulators? Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Hi
Yes,
On top of the cap, the spark plug wires plug into the cap. If those are called rubber insulators, then yes. |
Member 911 Anonymous
Use a pick tool and carefully slip it under the lip to make an air gap and then pull off. Wen you re-install get some dielectric grease and lightly smear some inside the insulator/sleeve/plug but not the wire lead and use the same pick tool to remove all air gaps.
You must hear a "click" to insure full contact of the lead to the leads on the dizzy.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Please do not pull on the wire yet. Gerry
There are special rubber tipped grabber tools made for that.
Couldn't live without it.
http://www.amazon.com/KiWAV-Spark-Plug-Plier-Removal/dp/B009YFEMP6/ref=sr_1_10?s=automotive&ie=UTF8&qid=1465143526&sr=1-10&keywords=spark+plug+removal+tool
Wow, priced well too. Guess what I am gettin Thanks JW!
You can use one of those nylon or plastic trim tools to get under the rubber boots to loosen them. They are stuck to your cap.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
3.2s (and later) have a ridged pin in the cap terminal and the wire end is female and they get a grip on each other. It's not just the boot.
I just used a screwdriver to kind of scrunch up the boot a bit, creating a pocket of air. That worked. They didn't come off easy but also not that hard. Getting the new cap and rotor on was a breeze. I appreciate the help y'all.
Together with the plugs the idle seems a bit smoother and revs seem more eager. |
Outstanding!
Use the tool that John Walker recommended. I did, and it worked like a charm.
Get it @ Harbor Freight |
Right, but isn't that thing for the spark plug boots? I had no problem with those.
Why pull them if you are going to replace them?
Search results for: 'spark plug' I don't see anything at HF except this Spark Plug Boot Puller
1986 Bosch Icon Wipers coupe. |
On mine, I had to get a pair of pliers and squeeze the top of the cap. After rotating back and forth and then leaning the pliers a couple of degrees this way and that it popped off. That tool looks pretty handy, tho.
1986 911 3.2 Cabriolet "We all have a desire to create something that will show we were here. " Ferry Porsche |
Functionista
When you put them back on use talcum powder between rubber and plastic surfaces. It is even the recommended service procedure for 2017 911s. It is for removal purposes at coil/plug interface.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Talcum Powder, interesting.
I got it at Amazon, there are several there, here's one: Amazon.com: Lisle 52990 Spark Plug Pliers: Automotive Sorry, first misteak I ever maid. |
