pins 1-3 are connected internally - .1 to .3 is OK pins 1-4 measure the internal capacitor thru the transformer and should not measure any resistance, if they do (2250 ohms) it indicates a shorted capacitor. pins 2-5 that's the tach output to the power input - of little value pins 1-5 is the power input to the internal ground. You need to measure pins 3-6 of the CDI harness and not the CDI unit to check for a distributor signal (600 ohms, .5 - 1.0 volts A/C while cranking) Again, if you measure resistance between pins 1-4 and/or by reversing the leads, you've found the problem - a shorted internal capacitor, which typically happens when there's a weak capacitor and the key is left on.
Dave Last edited by mysocal911; 06-12-2016 at 02:22 PM.. |
I haven't had time to measure the harness but I'll do that tonight.
I think I'm going to send my unit to Ingo in Santa Barbara. That seems like the best/quickest solution. I was going to buy a used "good running" unit but who knows if I end up with a marginal or bad unit that way. |
Pelican Parts Catalog:
Bosch CDI Repair Service ** CUSTOMER MUST SEND THEIR CDI UNIT IN FOR REPAIR ** (includes 1 year warranty) [More Info] 911, 911S, Carrera and 911SC (1974-89) 930 Turbo (1976-77, 1986-89) AT-CDIREPAIR Bosch CD Ignition Units [view in catalog] $200.00
Dave |
I got my CDI back from repair. Car started right up!
Thread Tools | |
Rate This Thread | |
