anthony's Avatar
No Start after leaving key in on position for 30 min
I was working on my power window regulator and left the key in the on position for maybe 30 minutes. Now the car will not start. It just turns over. I swapped the red relay for another (good one). That didn't help.
Is it possible to burn something out by leaving the key on?
Car is a 1981 911SC. All stock CIS.
Thanks!
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 06-04-2016, 07:09 PM
Reiver
Reiver's Avatar
Can you hear your fuel pump running when in the on position without turning it over?
De Oppresso Liber
Strength and Honor 5th Legion
Old 06-04-2016, 07:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Battery drained below minimum voltage. Jumper it or push start and drive her around for an hour
Check voltage I bet it is below 12.5
'85 Carrera Targa
PCA/POC
Old 06-04-2016, 07:14 PM
DanielDudley's Avatar
Put it on the charger and walk away. Don't get spooked.
Old 06-04-2016, 07:30 PM
Yep you drained the battery. .
Old 06-05-2016, 03:52 AM
Almost Banned Once
sc_rufctr's Avatar
Thanks!
It's not a dead battery lads.
"1981 SC"... Check the fuel pump relay. I'd bet you bumped it when you were working on the electrics at the fuse box for your power windows. (Reiver is on the right track)
- Peter
Old 06-05-2016, 04:12 AM
OP states it turns over- if starter turns, the battery can't be drained down too much.
Rutager West
Pull the relay and crank it over several times then reinstall the relay and it should start right up.
Old 06-05-2016, 05:42 AM
anthony's Avatar
That didn't work. What would be the point of pulling the relay?
It's not a dead battery. Battery was 12.2v. Car turns over fine. I gave it a little charge anyway which didn't change anything.
I was working in the passenger side door. The window regulator and motor now work perfectly.
So, is there anything common that can burn out by leaving the car in the on position. If no, I will start basic troubleshooting (fuel, spark, etc).
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 06-05-2016, 08:44 AM
DRACO A5OG's Avatar
Did you smell fuel when cranking?
If not, then pump may be out.
Also, 12.2v is not good enough, try charging for a little more or jump it.
'85 Carrera Targa
PCA/POC
Old 06-05-2016, 08:59 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Spark.
I don't think It's the coil, but, check for spark by
pulling #1 & grounding to the engine.
How old is the battery?
Also, check the battery voltage while cranking the engine.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-05-2016, 09:51 AM
Chances are you burned up your coil.
Old 06-05-2016, 10:07 AM
Burned coil, stuck/burned points, bad CDI.
Old 06-05-2016, 10:13 AM
You need a minimum of 12.5, once you know your battery is ok, proceed to other items if it still won't start.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-05-2016, 10:26 AM
anthony's Avatar
I ruled out the battery. I did put the charger on the battery last night and topped it up. It still doesn't start.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 06-05-2016, 10:44 AM
Can you hear the fuel pump running?
If it has points, put a new set in.
Are you getting spark?
1991 C2 Turbo
Old 06-05-2016, 10:47 AM
ROW '78 911 Targa
timmy2's Avatar
'81, no points.
Green wire to dizzy in good shape?
Get your battery voltage up first as others have said.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-05-2016, 10:52 AM
DRACO A5OG's Avatar
OP, any unburnt fuel out of tail pipe?
'85 Carrera Targa
PCA/POC
Old 06-05-2016, 11:17 AM
83 SC
tkmoore's Avatar
A little different look at this, but do your interior lights work when you open the door? I ask because you were working inside the door and the CIS lambda oxygen sensor/fuel frequency valve system operate on the same circuit as the interior door lights/door switches in the inner door sill. A non functioning lambda system will make car hard or fail to start. Maybe you accidentally disconnected or shorted the interior light switch and need to just check your fuses? Good luck, Tim
Old 06-05-2016, 11:27 AM
anthony's Avatar
Is the cis/lamda the box under the passenger seat?
Battery is good. I hear the fuel pump run.
Unfortunately I haven't had more time to work on it today.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 06-05-2016, 04:19 PM
