Headlights
Hey guys
Can anyone tell me the typical behavior of the headlights for a 911sc
Pulling the switch one notch turns the lamps on but very dim (wasn't aware they come on) this should also activate interior lights dash ashtray defroster controls?
Pulling it two notches turns the low level lamps on
Switching the stalk to high beam turns them on high beam
Flashing the stalk flashes the high beams
Old 06-03-2016, 03:16 AM
Pulling the switch to the first notch should not turn on the headlights. The fact that they are dimly lit indicates a voltage leak/feedback from the circuit which should activate only the parking lights and dash lights. You may have a poor ground that allows the current to flow through the headlight circuit to ground itself.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-03-2016, 07:50 AM
I think that your lights are fine!
The first position on the switch does not turn the headlights on (dimly), it turns on the 'City lights" that are inset into the headlight housing. These are low wattage extra bulbs for use in European cities when even dipped headlights are considered too bright. Look carefully into the headlights in this position and you should see the smaller bulbs near the main bulbs are all that is lit.
1982 911SC Wine Red Metallic
OMG I love this car!
Old 06-03-2016, 08:02 AM
There's definitely something wrong I don't even know where to start the dash lights I got working but I think it all may be ha use of a bad ground..I have a really bad feeling I'm going to have to pull this whole harness
Old 06-03-2016, 08:03 AM
Thats correct, they are the only ones lit..but there definitely is some strange stuff going on in the gauges they are terribly dull and the blue light turns on in the speedo only when I don't have the ground connected to it..making me think there is some strange voltages from somewhere
Old 06-03-2016, 08:06 AM
Bad grounds usually cause most of this kind of problem. Also remember, the dash lights never were very bright! Check all grounds and put LED dash lights and you may not have to pull the harness. Good luck!
Old 06-03-2016, 08:13 AM
There pretty bad
Old 06-03-2016, 08:21 AM
porwolf's Avatar
About those "City lights": The 2 or 4 Watt small light bulbs in the original headlights, like the Euro H4's, were designed not as driving lights but strictly as parking lights. It always has been illegal there to drive with them instead of the regular high or low beam lights. Those "City lights" are way too dim for using while driving at dark under any circumstances.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 06-03-2016, 08:53 AM
ROW '78 911 Targa
timmy2's Avatar
Pull the dash light blue/black wire off the light switch and un 12v direct from the battery to the wire. If they go bright then the rheostat in the switch is limiting the current too much.
Did you turn it all the way bright ?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-03-2016, 09:03 AM
I moved the lights over to The license plate tab assuming this would be maximum output voltage
Old 06-03-2016, 04:33 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Wow, I've seen low yellowish gauges but never that dark.
Sure like to see the bulbs on a direct battery lead, you did verify the proper voltage bulbs, right?
'85 Carrera Targa
PCA/POC
Old 06-03-2016, 05:13 PM
If it's illegal to drive in the city on 'city lights' and they are only meant for parking, what are 'parking lights' meant for?
Old 06-03-2016, 05:17 PM
Using Narva 12.5v 2watt globes pretty sure they are the correct ones.
I've put one accross the battery and it's hard to compare to be honest
Old 06-03-2016, 06:03 PM
What?
trj911's Avatar
Mine were like that and I switched to LED bulbs. Much better!
Tom J.
911SC Cab
SCWDP
CaymanS
Old 06-03-2016, 06:20 PM
SCadaddle's Avatar
The "parking lights" are the amber turn signal lights/lenses in the front bumper and the rear turn signal lights. With no key in the ignition and the light switch in the OFF position, move the turn signal stalk to one side. Those lights should be on continuously. Try the other side. It depends on which side of the active street you park on as to which ones to illuminate.
Old 06-03-2016, 06:55 PM
Switching over to LEDs..unbelievable how crap these are ha
Old 06-03-2016, 07:31 PM
ROW '78 911 Targa
timmy2's Avatar
12.5v 2 watt lamps sound correct.
Shut the gararge door and go completely dark for a while and see if it looks ok.
Dennis
Old 06-03-2016, 07:32 PM
porwolf's Avatar
The so-called 911 "city lights" are electrically connected to the parking lights and operate just the same. They are on when the parking lights are on.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 06-04-2016, 02:25 PM
+1 - they were RoW only and I highly doubt there are any city light police as they just look like dim day running lights on any other car on the road today. For daytime driving, I always use city lights and I don't intend to molest the factory 4-watt bulbs. I like them dim and if you want bright, just turn on your headlights
Old 06-04-2016, 03:36 PM
Seeing mine is AUS delivered I'm going to go with this being normal then!
Cheers guys!
Old 06-04-2016, 04:46 PM
