Born to Lose, Live to Win
ramonesfreak's Avatar
Trouble reinstalling rocker covers
Just put new rocker covers on. Got the top 5 screws in on both sides and both rubber strips back on
Cant remember how the bottom 3 bolts on each side go. Specifically, the plastic washers.
There are 6 thin plastic washers and 3 wider plastic washers.
Can someone please explain how and where these go? Unfortunately, it took me a year to get this job done since removing old rocker covers and I didnt take photos or make notes...just threw all the parts in a box like an idiot
Bently manual is of zero help with this
Thanks alot
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 06-09-2016, 05:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Those spacers go between the body fast nut screws and the rockers. Without them the rockers will be skewed in too deep and not properly follow the body lines.
Post a pic and we can tell you the order of the fixture components.
Do not over torque the fast nut is really thin and will strip easily.
Here you go Brother:
'85 Carrera Targa
PCA/POC
Old 06-09-2016, 06:00 PM
thanks. I figured the plastic washers go in that area, under the metal trim
what has me confused is that there are only 3 wide washers but there are 6 thin washers
Do all three wide washers go on the driver side in addition to 3 thin washers and then on the passenger side, just the other 3 thin washers?
I seem to recall all three fat washers coming from just one side. I made a metal note of this but well....my mental notes are not good
1983 911sc
Old 06-09-2016, 06:34 PM
This thread is related...but doesnt correspond to my original parts even though I too have an 83
All my screws for the bottom are the same length...also the thread is indicating 3 small washers/spacers and 6 larger...i have the opposite. I have 6 small and 3 large
White Spacers for Rocker Panels
1983 911sc
Old 06-09-2016, 06:40 PM
DRACO A5OG's Avatar
How thin are the thin ones? will two equal one thick one?
PO body shop may have put the wrong ones?
'85 Carrera Targa
PCA/POC
Old 06-09-2016, 06:41 PM
DRACO A5OG's Avatar
Oh Okay, driver side uses the thicker ones because it does not have oil lines plus a thin washer.
Passenger side, thin washer on top of the oil line bracket. Just checked my car.
'85 Carrera Targa
PCA/POC
Old 06-09-2016, 06:45 PM
So driver side uses 2 per screw...one thin and one fat? That does make sense as the gap is larger due to no oil lines
Thanks alot
1983 911sc
Old 06-09-2016, 06:48 PM
DRACO A5OG's Avatar
Yes, screw, thin washer, rocker, thick spacer to fast nut.
Passenger side, screw, thin washer, rocker, oil line bracket to fast nut.
'85 Carrera Targa
PCA/POC
Old 06-09-2016, 06:51 PM
