Me80SC
80 Row cold start fuel issue?
First off thanks for the help.
Trying to determine where to continue troubleshooting a no start issue. Believe the issue lies somewhere in the fuel system. Background: A couple of months ago the car started to exhibit a small whine upon decel, in gear only when letting off the gas. The last week or so the whine grew louder and the day before the no start the whine was noticeable when in gear and off or on gas. Two days after this the car wouldn't start. I originally thought it would be a faulty decel valve which could be plugged or replaced. Now I'm wondering if it could be a blocked fuel filter or other component. No start video As you can see everything cranks and car turns over, just doesn't catch. Already tried popping the clutch down a hill, reason for the rope to pull the car out of the garage. Confirmed spark at the plugs. Checked airbox, CDI is new rebuild from PO, confirmed fuel into the distributor. My next steps are going to be fuel pressure into the FD. Is there anything else I should be looking for next? |
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Member 911 Anonymous
Try starter fluid, to see if that will keep the car on for a bit. This could confirm your fuel starvation as culprit
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Me80SC
Thanks, I'll read through the additional post, also read the common start issues sticky and the Bentley manual. I'll try the starter fluid later today.
Me80SC
Read through a lot of the CIS material, and used carb fluid. The car will start with the carb fluid in the intake system and run until it runs out of fuel. It does not start or run with the FP relay bypass. Also figured out I don't actually have a decel valve on the car at all!
I have to run down a fuel pressure kit, however does anyone have any tricks for removing the fuel line connections. I've sprayed pb penatrent for the past three days and tried to remove the return line connection after the T without any luck. Video link Last edited by meichten; 06-04-2016 at 05:03 PM.. Reason: Add video |
ROW '78 911 Targa
WUR blocked?
Get you gauge and check fuel pressures.
Me80SC
Just tried a spare WUR yesterday no dice. Need to locate a guage today.
whine coming from the front? fuel pump might have been on the way out...and now finally died...
before: '69 Porsche 911T bahama yellow now: 1981 911 SC Targa winered |
76 911S Targa
Lift up on the sensor plate to get fuel flow through the system. If you do not hear the fuel pump, you know your culprit.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
ROW '78 911 Targa
Pop out a fuel injector and put it in a jar to collect fuel with line attached.
Turn ignition on and then lift the air metering plate to see if fuel is flowing out of the injector.
Me80SC
When you say turn ignition to on, you mean to the on where the gauge lights turn correct? The next rotation of the turn would be to the start position? Do I need to do the fuel pump relay bypass or not for this step?
Yes turn to the on position.
No need to bypass the relay as when you lift the air metering plate the pump will turn on.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Read DKLever48's post about FP relay operation........
meichten, Do yourself a favor by finding time to read DKLever48's posts about FP relay. Everything you need to know and understand about its operation was broadly discussed in it. Instead of repeating verbatim the procedures, reading the posts would be more suitable in your case. It is very informative and will guide you how the test and analysis are performed by DIYer's like ourselves. Keep us posted. Tony |
Me80SC
Completed the FP and injector test.
FP kicks on without issue, however empty bottle, so no fuel to the injector. Wreckah The whine was coming from the engine bay, like a high pitched whistle. |
In the absence of a fuel gauge.......
meichten, A running FP means nothing except that the motor is turning. You need to know the delivery pressure or volumetric flow of said pump. In the absence of a fuel pressure gauge, measure the flow rate of the FP. A flow rate of 1 liter (min.) per 30 sec. would be sufficient to generate the required system pressure. If the FP is good and running, and the system fuel pressure is too low, you won't be able to deliver atomized fuel through the injector/s. So it is mandatory to have a fuel gauge kit available to have a meaningful troubleshooting in any fuel injection system. Without one, there are too many unknown variables. Tony |
ROW '78 911 Targa
So, no fuel flowing from removed injector with the fuel pump running and ignition to run position while you lifted the air metering plate?
Get a gauge on there and start testing.
Me80SC
Was until a few minutes ago, just cleared a clog at the T on the return and now I do get fuel out of the injector, however still no start. Off to store for gauge.
Me80SC
System pressure looks about right per Bentley.
![]() Control pressure looks good and in range. ![]() I do also hear a high pitched whine around the back of the FD sporadically while running the test. |
Me80SC
Got it started running ruff
GOT IT STARTED!!!
First put 5 gallons BP 91 in the tank to add to the other five. Wasn't getting a good voltage reading at the coil, replaced that and the battery post negative cable. ![]() Coil ![]() The car now starts, runs really rough and no power. Running video Replaced spark plugs ![]() ![]() Searching the forums for no power issues for next steps now. |
