San Diego, CA
Sunroof Maintenance
My sunroof is slow and requires a little help the last few inches. Is there a recommended lube maintenance and at what places?
Old 06-04-2016, 11:06 AM
DO NOT lube anything! It will only gum up the works and make things worse! There are many threads on the forum concerning sunroof problems. Use a Google Advanced search for "sunroof problems" and you will find many results.
Also, read this tech article on sunroofs and perhaps it will guide you in the right direction.
http://www.pelicanparts.com/techarticles/911_sunroof_repair/911_sunroof_repair.htm
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-04-2016, 12:18 PM
San Diego, CA
Porsche 911 Sunroof Repair | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
That's why I asked. Thanks!
Old 06-07-2016, 10:49 PM
emac's Avatar
Use it more often. That was posted a few years ago
Ernie
Old 06-08-2016, 05:19 AM
Discseven's Avatar
"Slow"... thinking either motor is worn, cable(s) are gummed up / screwed up, there's interference somewhere, or combo. Not sure what year you have but for a '79, only takes a few minutes to have the whole thing apart. Must be thread on this topic.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-08-2016, 06:58 PM
