Diagnose this Scenario
Please diagnose this scenario ...
![]() I recently took a long trip up and down California, to Vegas and back, etc. The 81 911SC ran flawlessly. In fact, it seemed like it had never run so well. I got a friends house in Northern California and parked it. Two days later, I started it up and it ran like ***t. Real rough like running on 4-5 cylinders. I pulled the plugs and things looked fine. I replaced them just in case. Started it up and it still runs horribly. Spark plug wires are one year old and still look new. Could it be the coil? Possibly a clogged injector or fuel distributor? Anyway, I'm hoping someone has experienced this same scenario and discovered what it was and could share it please!
1981 Porsche 911SC, 2001 Porsche Boxster, 1963 Jaguar MK2, 2001 Jaguar XJR, 1991 Mercedes 500SL, 1973 Opel GT, 1981 Mercedes 380SLC, 1994 BMW 325ic, 1980 BMW 320is, 1983 BMW 320i, 1974 MGB, 1999 Audi A6, 1995 BMW 740iL, 1995 BMW 325iC |
Fuel filter at bottom of tank? Coil? Cyl head temp sensor?
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
O2 sensor relay under the padsanger seat.
I just had a similar problem. Bad gas and then the relay failed.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Pull the distributer cap and check for moisture.
1976 911S MidYear Fever is alive and well. |
Thanks for the replies. I shall check into all of your suggestions. I appreciate the help!!!
Member 911 Anonymous
Check for vacuum leak too
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
did it backfire when starting. if so check the pop off valve to see if it is seated/closed
fuse 18 good drive it and see if it clears up
We had the weather clear a bit here and I've been driving my 81 the last three days.
It was glorious Wednesday and yesterday. This morning on the way in to work ( a twisty, hilly two lane for 14 miles) I had a hesitation / miss after warm up. Idle also seemed a bit high. Checked under the hood when I arrived and nothing is obviously amiss. I'm suspecting a vacuum leak somehow, but I just got all of those fixed!
1981 911 SC 2013 Mini Cooper JCW 2017 GMC K1500 |
If the OXS relay and control box is good you might have a vacuum leak close to the intakes, like the rubber connectors on the runners or the injector seats and o-rings. Perhaps a big airbox leak?
I remember a couple of guys complaining about symptoms similar to what you describe. One guy found a big hole in a rubber connector between the aluminum runner and the airbox. You can pull your relay when the engine and is running and if there is no change then the relay/box or wiring is bad. Also check continuity to your control box and relay too. Does your cabin light work? It runs off the same fuse.
