86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/C Hi-Lo Pressure switch.
Need the High/Low pressure cut-off data for this switch.
Could not find any P/N.
Thanks in advance,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-19-2016, 09:44 AM
Pull the switch apart.
No, really! The rubber part pulls off with the wires. It's a tight fit, pull hard. On the part of the switch that is exposed, it will show the high and low pressure cut off values.
Problem is, it's probably in metric, so it'll be something like 2 and 28 kg/cm^2. To convert to pounds per square inch, take the values and multiply by 14.22 (14 is good enough).
I have two switches on my workbench, both are on at 2 kg/cm^2 (basically 28 psi), while they turn off at 24 and 28 kg/cm^2 (336 and 392 psi).
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 06-19-2016, 07:33 PM
Switch.
So the switch shuts off the compressor at a 24 psi low side?
How about the high side?
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 06-21-2016, 11:25 AM
Shuts it off when below about 28psi, and above about 350 psi. Allows it to run between those numbers.
So, it shuts it of if you lose all pressure, or if there is a blockage and you over pressurize the system.
Mike Bradshaw
Old 06-21-2016, 11:32 AM
