a/c question - increase in vent temp the day after new charge
A quick question on a/c (don't shoot me). Yesterday I completed installing a fender condenser and charged the system. I got low thirties at the vent on an 80 degree day. Now today it is only 4 degrees hotter outside and I get about 48-50 vent temp. I assume I need to look for a leak. Could it be anything else?
Thanks,
Hoppe
Old 06-20-2016, 11:22 AM
Put the gauges back on and see what the numbers are like. Or, get a static pressure and see if it compares to the ambient temp.
You might even be able to hear a leak, get it up to working pressure then shut the car off, 240psi will hiss audibly.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 06-20-2016, 11:43 AM
kuehl's Avatar
Assuming you evacuated the system and charged it properly, and you have no leaks.....you need to compare apples to apples and record all your data.
Windows up, fresh air controls in the dash to the left, heater box valves closed,
testing pressures at "idle", deck lid resting down on its stop, service hoses to the right of the compressor pulley, let system run for at least 5 minutes, fan speed 2, thermostat max cold, and at idle:
1) Ambient temperature around the car, and is it a sunny day or cloudy day.
2) Low and high side pressures
3) Vent temp from the center vent
Then drive the car, after 15 to 20 minutes 35-45 mph, what is the vent temp at fan speed 2, what is the outside air temp.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 06-20-2016, 01:33 PM
Looks like I do have a leak. I used UV dye so I was able to put a black light on it tonight. It is at the hose connection coming out the the original condenser. The last connection I made when hooking everthing up after flushing the system. Used a new O-ring and tightened it down snug. I guess I will need to get the system evacuated and try again. Good news is the rest of the sytem appears to be leak free.
Old 06-20-2016, 06:10 PM
kuehl's Avatar
Good job solving the issue.
I forgot to torque my cylinder jug allen bolts last month.
Kuehl
Old 06-21-2016, 02:32 AM
Thanks; however, I will consider it solved when it does not leak. Not sure why it does, unless over tightening could have caused the issue. I don't think I lubed the 0-ring either so may that's it.
Old 06-21-2016, 02:49 AM
kuehl's Avatar
Disconnect the hose fitting from the original condenser (use 2 wrenches, one to hold the fitting on the condenser and the other to turn the nut on the hose fitting; this is for readers).
Remove the o-ring.
Inspect the "bubble" or "bead" on the hose fitting that backs up the o-ring when the nut pulls fitting into the condenser. The shape of the bubble bead should have a round form on its outer edge. If it is flared back toward the nut the fitting was over tightened and o-ring will not seal.
Inspect the o-ring seat inside the bore of the condenser fitting to insure there is no debris or corrosion.
If you get stuck give us a call.
Kuehl
Old 06-21-2016, 03:01 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Vacuum.
Others may "chime" in, but I don't think that
pulling a vacuum with a 1 1/2 pump pulls
the oil out of the system.
G.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-21-2016, 07:37 AM
Which raises a good question. If I evacuate the refrigerant and open the system at the point of the leak, do I need to reflush and then re-oil the compressor or do I just need to close it up and pull another vacuum?
Old 06-21-2016, 10:21 AM
kuehl's Avatar
If you need to remove the refrigerant and fix the leak, depending upon what you fix you may or may not need to add replacement oil.
Examples:
Compressor replacement 2-3 oz max
Drier 1-2 oz max
Evap 2-3 ox max
Deck lid condenser 1-2 oz max
Front condenser 1 oz max
Replace an o-ring nothing
Replace evap to compressor hose 1-2 oz max
We can go on and on
Kuehl
Old 06-21-2016, 11:16 AM
kuehl's Avatar
The oil is a liquid that won't evaporate under negative pressure.
The only oil that typically leaves the system on a 911-930 with a denso or 507 is oil near the suction port of the compressor. If you just filled the compressor with oil you are gonna have some flow out, maybe 1 oz max (gravity), if the system has run with oil for a while ... less than 1/2 oz might flow out.
Kuehl
Old 06-21-2016, 11:18 AM
Examples:
Drier 1-2 oz max
Evap 2-3 ox max
We can go on and on
email sent.
Gerry
1986 911 Targa.
Only in L.A.:
Old 06-21-2016, 11:19 AM
kuehl's Avatar
Originally Posted by 86 911 Targa View Post
email sent.
Gerry
No spam Gerry
Kuehl
Old 06-21-2016, 11:36 AM
