Installing Timing Chain Covers
Should you use a gasket adhesive when reinstalling timing chain covers after tensioner upgrade????
Old 06-21-2016, 05:33 AM
Depends if you ever plan on pulling them off again.
If yes, skip the adhesive and fight the fight of getting it to seal with just the gasket.
If no, I used permatex copper spray sealant which worked great.
Old 06-21-2016, 05:55 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
If one is to use a sealant/adhesive, the consensus appears to be Curil-T sealant. A search (especially on John Walker's posts) will help in your decision.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 06-21-2016, 10:15 AM
gtc gtc is offline
abides.
gtc's Avatar
I used threebond 1104 per the complete engine sealant thread. Not fun to remove and scrape (Had to do one of them after I messed up the assembly procedure), but there is no way they're ever going to leak.
Graham
1984 Carrera Targa
Old 06-21-2016, 12:31 PM
theiceman's Avatar
i used the yamabond ( 1104 ) very thin coating on the gasket.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-21-2016, 01:00 PM
Discseven's Avatar
My vote: Clean-clean-clean mating surfaces... then sealant.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-21-2016, 02:36 PM
