Exclamation Violent Jerking while driving at low rpms.
1980 engine. The car starts just fine. It sounds very smooth and idles nicely. However when driving on the street, it really struggles in the low rpm's.
For some time I thought the car was simply going to slow to be in the specific gear, but my father drove the car and said that this problem isn't due to that and was not there before. The car runs great at the higher rpm's and is powerful and smooth. The issue occurs on flat ground and on an incline when the car is under load. I believe the violent jerking occurs in all gears, although very rough while in second.
I have thought about the possibilities of a bad fuel filter, fuel pump, dirty injectors, or possibly a vacuum leak.
I have also considered the possibility of a bad fuel to air ratio, however, the car was recently tuned.
Any suggestions and help would be appreciated.
Cheers!
Anthony
Old 07-21-2016, 06:25 PM
RETIRED
Joe Bob's Avatar
Could be any of that but I would suggest taking it back to the wrench and blaming it all on him......
2012 ML350 3.0 Turbo Diesel
Old 07-21-2016, 06:33 PM
Well, here's the thing, it was tuned when taken in for a smog test, and was running fine for a while after. The issue only developed recently, so I'm inclined not to think it had to do with the mechanic.
Old 07-21-2016, 06:42 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Does the car attempt to stall out? Im guessing vacuum leak with the info you have given. Change the fuel filter if you don't know when it was done last.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 07-21-2016, 07:02 PM
Yes it was attempting to stall. I'm leaning towards vacuum leak as well.
Old 07-21-2016, 07:09 PM
EMT/TechRescue Instructor
86911cab's Avatar
Intake to head leak
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 07-21-2016, 07:28 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Use a cigar and find the vacuum leak/leaks
'85 Carrera Targa
PCA/POC
Old 07-22-2016, 01:17 AM
Wer bremst verliert
JohnJL's Avatar
Came here to see if Ronnie is around...this thread title is Ronnie-bait.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-22-2016, 03:49 AM
Helps to state what year it is....
206 637 4071
Old 07-22-2016, 04:46 AM
Agree we need to know what year / model the car is. All my old Solex and S cam cars had to run above 2700 RPM around town or they'd buck.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 07-22-2016, 07:19 AM
Yeah, like how long is this rope?
206 637 4071
Old 07-22-2016, 07:23 AM
Chain fence eating turbo
Oh, not all 911's are the same?!?!
Old 07-22-2016, 07:26 AM
A three second investiation leads me to conclude that he's probably talking about his '78 911SC.
My first suggestion would involve checking the CIS system and related issues. That's assuming that he's not trying to spin the engine at too low a speed in a particular gear.
It's also always worth having a look at the distributor, as these seldom seem to be serviced by most people.
JR
Old 07-22-2016, 07:32 AM
JR
You must be referring to his sig.?
If that is the case, when you use PP on a smartphone, the mobile theme does not show sigs., as I assume you are aware.
Old 07-22-2016, 08:20 AM
Fahren mit dem Wind.
mhackney's Avatar
Tippy, the OP doesn't have a signature but he does have a Garage that shows a 78 911 SC. You might not see this in the mobile view either. It's always best to explicitly state the model and year of your car in the first post for help!
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 07-22-2016, 08:27 AM
No, I wasn't looking at his signature, which doesn't list anything. I looked in his "garage" which can be accessed on a smart phone.
Not that I use my smart phone for perusing the internet... Being a (somewhat) older fart, I have not been surgically attached to my precious personal device and so I still use a computer of one sort or another to peruse the internet. I keep the phone around, in case I should get a phone call.
Not that it matters in this case...
JR
Old 07-22-2016, 08:47 AM
Counterclockwise?
How is it in the rain?
I'd check the distributor as already mentioned.
Rod
1986 Carrera
2001 996TT
Old 07-22-2016, 09:27 AM
JR
Right on, didn't think of that. To me, it's a simple courtesy to list vehicle and mods if any.
Beings you have "java" in your title, I figured you knew that already. HEHHEH
I use the Internet on my phone 100%. So easy and convenient.
Old 07-22-2016, 09:35 AM
Wrong again, Kemosabe. The java in my user ID has nothing to do with Java, as it relates to computers....
Back to the original topic, one other thing to look at would be the specific things done when it was recently "tuned."
JR
Old 07-22-2016, 11:15 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by 86911cab View Post
Intake to head leak
How do you know this because the only time my car ever bucked was when #4 runner at head was sucking wind.
Get the carb./brake cleaner out and find it.
1981 911SC Targa
Old 07-22-2016, 11:54 AM
