LinkBack | Thread Tools | Rate Thread |
So, my Elephant Racing oil cooler and fan is in, and I have to say it was a very satisfying project to complete on my ‘83SC. Early observation is that the kit is doing an excellent job at keeping the oil at a manageable temp. For example, I drove from the Philly ‘burbs to DC on Father’s Day, temps were 93 degrees, and it was pure stop/go traffic on the Blue Route (I-476) for 15+ miles, and the temp needle was pegged at the 9 o’clock mark, no higher. Normally, I would see the needle approaching the red zone in similar conditions with the POS trombone cooler. NICE! Plus, Chuck from Elephant was very patient with my questions along the way.
A couple of items to guide you if you are installing this kit:
Thanks for reading Pelicans! ![]() ![]() See the white plastic straw? ![]() Fan wires pushed through the straw, and into the frunk: ![]() Then pull straw back through the frunk: ![]() The thin black wire above the right-most horn is for the thermoprobe. Note use of the hole in the horn bracket as a routing channel. ![]() ![]() ![]() ![]() Installed! ![]() Last edited by garment; 06-24-2016 at 07:30 PM.. |
Did you consider painting the stone guard?
1982 911 Targa, 3.0L ROW with Webers |
No, I didn't. If you are wondering if I or anyone else notices the bright shiny stone guard, the answer is definitely no. With the wheel mounted, you have to do some serious "peering around the corner" to see the thing. Also, the guard definitely dulled since installation.
I wouldn't bother painting it. |
Thanks! I got my package from Elephant today and starting to plan...
Good points and nice write-up. I wish I had this when I did mine ~6 months ago!
A few points that I'd like to add: 1. The oil lines are a pain in the a$$ to separate. I ended up soaking them in penetrating oil for a week and did multiple rounds of heating and cooling with a plumber's torch. You can buy heat protection insulation from your local Home Depot to place behind the lines so you don't burn your paint on the fender. Use 2 wrenches!!!! Can't stress that enough. 2. There are measurements that I found in a post here on pelican to show where the lower bracket should go. I tried welding mine on, big mistake. After numerous attempts at welding and lots of time spent grinding failed attempts down I decided to riv-nut the damn thing on. Should have started with that. 3. The bracket you mentioned on the back of the headlight bucket was for the optional oil cooler that replaced the trombone. The OEM cooler would have used that bracket. On my car the back of the headlight bucket was cut out to make way for projector lights. I ended up drilling a hole and using another riv-nut. I took some flat stock and bent it up to meet the oil cooler. The top bracket in my car is purely to protect fore/aft movement so I wasn't worried about vertical strength. 4. I used Hella supertones for my horn replacement. Although the car now sounds like a Subaru the fitment worked well. 5. I had to undo one of the brackets holding the oil lines to the body. I ended up not putting it back on. The lines seemed stable enough and there was no way the OE bracket was going to reach. Time will tell. 6. Lastly I didn't use the clips to hold the stone guard on to the cooler. I ended up drilling small holes and used a machine screw / nut setup. I was concerned about tightening the top bolt with everything together and figured if the stone guard was more easily removable it would help down the line. Here are some pictures of my install: These are the horns I used. I re-used the stock brackets and had to make one my own. They fit well without any interference. ![]() The dark black you see on the back of the headlight bucket is tape but you can also see the metal bracket I made holding the top. ![]() Here you can see the trimmed stone guard. The original one I got from Pelican was stamped incorrectly (holes for the oil lines didn't line up) so I ended up cutting most of the top out. I did add an extension on the side since I have a turbo bodied car. I will say this is one area that needs some help as it's not forcing the air directly through the cooler but potentially around it as well. ![]()
1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html |
Thanks for adding to the thread Scott. Can you talk a little more about the rivnuts? Did you buy a tool or make one? Hesitant to buy since I only to install 2 inserts.
I did rivnuts as well. PM me with your contact info, I have a spare tool, I think was about $20 and I'll send on some nuts so you don't have to buy those. Can you pay shipping as well?
I don't have anything to add,other than a Big Thank You
You can make your own tool, you basically have to "pull" the threads out or in other terms just over tighten a bolt. Where do you live?
awesome work! thanks for sharing!! great documentation....
I cut the old bracket off the back of the headlight. Wondering if anyone used that to locate the new carrera bracket?
How am I looking on tire clearance? Gap is 1.5 inches.
Registered Minimalist
That's more than mine. I take it no fan?
What size wheel and tire?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I have a fan. 205/55/16 tires. I just redid every thing with the later carrera horn bracket. So far that investment has paid off it seems. I just couldnt get the cooler far enough forward with the sc bracket.
Great thread...
Question : has anyone also used the air scoop that is placed where the side marker light is on the car? Maybe the fan is sufficient enough? Thx, Bob
I live for 911 tweaks... |
I want the air scoop, but haven't bought it yet. Slightly peeved to pay 100 dollars for a small piece of plastic. I've run my ER finned lines with Carrera cooler and fan all summer in vegas and it's worked like a dream. Never got above 240 and ran at ambient 110 degrees in some cases. Don't really need the scoop but 1. It looks cool and 2. Can't go wrong with even more air hitting the cooler fins.
Nice install. Used the same kit years ago. Just recently found fan below mentioned on the 930 forum, bought it, ran it side be side with the ER fan and there is just no comparison. The ER fan does not even seem like it's moving air compared to the AV fan, so I dumped the POS ER and installing the AV fan. It's worth the $29 just to buy it and see for yourself. Fan is also smaller, making it easier to install. I used 4mm bolts thru holes on the outside lip of the cooler when I previously installed the ER fan years ago, and the same with the new AV, as I did not like the cheap plastic ties.
Also, make sure you configure as push and nut pull, so I was told. https://www.americanvolt.com/collections/6-inch-fans/products/6-inch-small-slim-electric-fan-12v-radiator-oil-cooler-atv-mini-tractor-mower
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S Last edited by timc; 09-24-2017 at 07:25 AM.. Reason: clarity |
Thx timc for your post...
So, did you use both er fan and the American volt fan OR two America volt fans? Please clarify and if you have any pics please post. Thx
I tossed the ER fan and will be using ONE 6" American Volt by itself.
If you lay these down and run them side by side, you will astonished at the amount of air the AV moves compared to the ER. When I was in traffic with the ER, it would keep my temps down for around 15min or so, then they would slowly overtake it's ability to keep the temp stable. I am sure the AV fan will prolong this, but I don't think any of these fans will allow me to just sit in traffic indefinitely, and that's ok, it's nice just to buy more time....but then I generate more heat than a 911.
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S Last edited by timc; 09-23-2017 at 06:21 AM.. |
Great thread guys
