KatoKato's Avatar
Fuel Delivery Issue - 3.2L Carrera
I was out on a run this weekend and after a brief stop I went to start the car. Starter motor going, engine not starting. After a couple more attempts I figured I wasn't getting any fuel. On a fourth attempt I had my son engage the throttle from the engine bay as I turned the engine over and voila! ---- the car starts.
After a brief drive I noted an an upshift into second that I lost power for a half second or so and continued on. I noted this one more time just a short while after.
On a related note, in the past few weeks I have noticed that while at a constant speed on the highway the car would lurch for a millisecond or two --- kind of like the clutch was slipping. I am thinking that this is related.
I was able to drive home without any issues and had two more stops without any issues starting.
Any ideas on what this could be? Most likely culprits?
Cheers and thanks,
Kato
Old 06-13-2016, 07:06 AM
do you have a spare DME relay? It activates the fuel pump, etc. and can develop bad soldier joints that cause intermittent failures. Easy to rule it out by replacing with a spare
Old 06-13-2016, 07:42 AM
Elombard's Avatar
^ do some searching on DME relay. Sounds likely and similar to issues I had. You can jumper the pins to eliminate it but that wont help if its intermittant.
Love your Avatar! they just dont make movies like that any more.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-13-2016, 11:39 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+2, swap relay and keep us updated :-)
You should have a spare non-Uro one.
'85 Carrera Targa
PCA/POC
Old 06-13-2016, 11:45 AM
KatoKato's Avatar
Yes --- I have spare relays. I will try this and see if there is an improvement. I should have thought of this but I've been out of it for quite some time. I've been enjoying the car without any major issues for awhile now.....
Thanks much.
Old 06-13-2016, 04:24 PM
KatoKato's Avatar
Originally Posted by Elombard View Post
......Love your Avatar! they just dont make movies like that any more.
Thanks .... yes .... classic. Aliens is my favourite Sci-Fi film. Early James Cameron work. When my kids and I watched Avatar they said, "hey. didn't they have those in Aliens" Referring to the machinery, of course.
Old 06-13-2016, 04:27 PM
autojack's Avatar
I'm dealing with this in my 88 right now. I had the same lurches as you, then the car died. I got it to run briefly several times but not long enough to drive it. Eventually it wouldn't start at all. In my case it wasn't the relay. I've confirmed I have spark (after something of a wild goose chase) and now I'm preparing to test the fuel pump. Follow along at Broken down near Pt. Reyes, CA
1988 911 coupe
1976 Vespa Rally
2015 Honda HR-V
Old 06-13-2016, 10:30 PM
KatoKato's Avatar
Originally Posted by autojack View Post
I'm dealing with this in my 88 right now.....I'm preparing to test the fuel pump. Follow along at Broken down near Pt. Reyes, CA
Yes ... these fuel pumps are getting old!!!
Just to update ... yes ... it was the DME relay. Changed it over and no problems at all.
Cheers,
Kato
Old 06-28-2016, 11:25 AM
