Banned but not out, yet..
RSBob's Avatar
Cruise Control Repair New Source under $100
There is another thread about CC repair but the Mercedes repair guy either retired or was kidnapped. I wasn't going to pay the guy on eBay $200 so I found Automotive Scientific Inc. Their reviews were shaky so I called them first and got some reassurance. They did the repair on my surge problem for $89 with a life time warranty. The unit now works great with no surging. My only issue was it was not shipped back insured so you may want to request that. Getting ahold of them by phone is no issue. No affiliation.
Old 09-14-2015, 09:53 AM
Cruise repair.
Here is another option, CruiseControlRepair.com , quick turn around , good communications, good work product.
Old 09-14-2015, 12:53 PM
What was the specific repair you got? Inop? Surging?
Old 09-14-2015, 05:31 PM
RSBob's Avatar
My issue was surging. I would set the speed and it would hold for a few secs and then drop about 5 mph and them rapidly accelerate back to the set speed, then drop off and repeat until I was so fed up I would disengage. Now it holds just fine.
Old 09-21-2016, 07:57 PM
That seems kinda expensive for replacing 2 $.50 capacitors and doing some re-soldering.
Surely you can find us a cheaper "repair guy". The shipping is at least included, right?
Dave
Old 09-21-2016, 09:02 PM
I sent two bad CC units to the Ebay guy before he raised his price from $80 to $190. When they came back I opened them up to see what repair was done. The ONLY thing done was to remove the "varnish" coating on the back of ckt board and a reflow of EVERY solder joint! Not a single component was replaced! They both work fine now.
I had several other bad CC units on hand and set out to repair them myself. Used acetone to remove the coating on the back of the ckt board (IMPORTANT). I then proceded to reflow all the solder joints using a somewhat low wattage pencil type soldering iron with a very fine point and some VERY fine diameter solder. It's also important to use a magnifing device so you can see what you are doing. It's very meticulous work and takes more than an hour if done carefully. I have since repaired three of the bad units I had by reflowing the solder joints.
I also had on hand some new components, the two different "suspect" capacitors as well as the IC modules for replacement, but never needed them and the three units I fixed are still completly operable today. I suspect in the majority of cases a reflow will fix a unit and very few
will have bad components, at least that is my experience.
All in all,I agree, it seems $89 is a little pricey but for someone without the expertise to precisely "reflow" ALL the solder connections on the circuit board, it's probably a bargain! After all we don't mind paying $100 an hour labor for mechanical work and it takes more than an hour to completely reflow the CC solder joints.
To sum it up,if you are somewhat competent with a soldering iron, have a great deal of patience and feel adventerous give it a try!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-22-2016, 07:22 AM
Uncertifiable!!!
Uwon's Avatar
uwanna, I've never opened the CC unit. How many capacitators are there and are they easily replaceable?
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 09-23-2016, 05:18 AM
Johan
Check out this thread, it has some schematics and pics as well as operational description. I have replaced some of the caps but it never fixed anything. If the
electrolytic caps on the board aren't obviously burned looking, chances are they are not bad. The ONLY success I've had fixing these units is a complete reflow of ALL the solder joints!
Understanding the VDO Cruise Control Amp
Old 09-23-2016, 07:11 AM
911tracker85's Avatar
my problem was the cable broke. forget what the cost for a new one, but fixed it using a $2 guitar string...
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 09-23-2016, 07:29 AM
