Jameel's Avatar
Identify this wire behind my dash?
In the process of replacing my fresh air blower and rewiring my cigarette lighter socket I came across this loose wire. It's white w/ green stripe and has a piggyback terminal. It's coming from a group of two other wires that go to the rear defog switch. It's an '83 SC Coupe. I'm away from my Bentley manual, but will check it later tonight.
Old 07-09-2016, 02:38 PM
Slippery Slope Victim
NY65912's Avatar
Don't know, but I'm interested as well. I have the same wire on my '85.
MikeČ
1985 M491
Old 07-09-2016, 02:44 PM
RETIRED
Joe Bob's Avatar
Page 970-23 of the Bentley says it is an indicator lamp. So check your dash gauge idiot lights.
2012 ML350 3.0 Turbo Diesel
Old 07-09-2016, 02:45 PM
In that area, could be for the HVAC panel lights?
Rutager West
Old 07-09-2016, 03:46 PM
Jameel's Avatar
That helps! But can you explain how you determined that from 970-23? I'm back at home now and am open to that page. There are two indicator lamps listed, oil pressure and generator. I don't think it's either one of those, I check those at every startup, and they were working just earlier today. More telling is that even if it were one of those, I don't think this wire is nearly long enough to reach over to the gauges. It's got to be something near the fog light/defog/seat belt light cluster.
Old 07-09-2016, 04:28 PM
RETIRED
Joe Bob's Avatar
Your wire is in the trunk by the dash. I simply looked for a labeled green/white wire in the schematic.
Old 07-09-2016, 04:35 PM
ROW '78 911 Targa
timmy2's Avatar
If it is with a black and a white/grey only, it is for the rear fog lamp in Europe.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-09-2016, 05:50 PM
Jameel's Avatar
So I poked around a little more in here and here's what I found.
The terminal marked "III" on the back of the fog light switch has nothing going to it. And I couldn't find a reference to this in Bentley. So I just left it alone. The switch works fine, powers on the fogs, and the switch illuminates when on.
Then I read timmy2's reply:
So I went back out and double checked the wire bundle. Yep, it was with a black and a white/grey only. Thanks timmy2. So now I'm wondering if the bare terminal on the fog switch is indeed for this wire, which perhaps the factory left disconnected for US cars since there's no rear fog here?
Old 07-09-2016, 08:00 PM
E Sully's Avatar
W/Grn is generally used for fog lights, or side marker(parking) light indicator on Speedometer.
Ed
1973.5 T
Old 07-10-2016, 09:58 AM
