2.7 engine harness to 914/6 (14 pin pinouts)
Greetings. I am building a 2.7S hot rod motor to be installed in a real 914/6. The wiring diagrams for the 914/6 are dreadful. I am wanting to mod the 1974 911S, 2.7 wiring harness to be compatible with the 914/6 14 pin connector...........I am very familiar with the 74-77, 2.7 engine harness.....but, can anyone provide a decent pinout for the 914/6, 14 pin connector(s)?
regards, al Note: this 2.7 engine is a EFI with M'squirt ECU....so the harness is modded already to work with that....but I would like to make the 14 pin connectors mate to ensure that the remaining active circuits are as plug n play as possible.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Vintage Owner
Pin out diagram
There is an excellent picture in George Hussey's (Auto Atlanta) booklet on converting a 914 to a 914-6. I'm in the hospital right now, so can't get to my copyright now.
Perhaps someone on the 914World or 914Club site may have a copy they can share. I have a 2.7 in my 914-6 conversion, and it really is a great ride with that engine.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
RETIRED
You could also talk to Timmy2 and have him build you a custom harness, plug and play.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
regards, al
regards, al
ROW '78 911 Targa
Emailed this to you Al.
leaves me without a warm fuzzy feeling as I don't see an alternator connection and 4 backup light wires?
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-07-2016 at 10:27 AM.. |
Yes, i see the backup light wires look to be afu...but the alt wires appear to connect to the relay board directly, using the alt/VR 3 pin connectors and then connect to the main harness via that control/relay pcb....see below the additional illustrations i've found with my added notes on the wiring diagram. regards, al ![]()
ROW '78 911 Targa
Funny thing is I have an original 914/6 harness in a box in my shop right now, just haven't had time to even take a good look at it!
Thanks for the additional info.
914/6
OK, I believe that I have the redundant backup light wiring figured out. Per the rear harness illustration provided by Jeff Hynes (I believe) pins 12&14, as well as pins 2&4 are designated for backup lights....but, if you review the relay board diagram that I supplied above, you will see that pins 2&4 are shown with different colors and designations. I've marked up the connector plug diagram to match what I think the correct wiring is.......
Please review and comment.........
