Any thoughts on Techron additive?
I've used gasoline additives on other cars with fair results but they weren't Porsches. Any thoughts on throwing a bottle of Techron in my '79 911 SC?
Member 911 Anonymous
Should be fine but plan a long drive to get the it all out asap. Your fuel lines and component may degrade faster if you leave it in the car for a long period of time.
Do a couple of I-tune ups to get all the carbon out or much as possible
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RETIRED
Yup, do it on a trip....a bottle is caustic, very little in Chevron pump gas by comparison....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Still here
My personal observation on my FPR. I made of mistake of leaving it for a long period of time and it damaged my FPR. Caused it to leak.
This also happened to my Lexus. Maybe I was unlucky or they were both ready to go after it's use, who knows but I feel better to play safe and get it out asap then have a potential problem later. Plus good reason for a road trip
Porsche did recommend Techron. I recently stumbled across a Porsche Technical Bulletin that explained their recommended procedure. IIRC they said to add it and fill to 1/2 tank. Run that through and then repeat process. If I can find the document again I'll post a link.
Not sure if this is required but I usually do this just prior to an oil change in case any gets in the oil. Hope this is helpful.
Dave 1985 Factory Turbo-Look Coupe 2011 Cayman S 2012 Audi S4 |
+1 on doing it right before an oil change.
Mat P 1988 911 Carrera |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Porsche/Techron.
![]() ^^^^^ Here you go..... Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I have used Techron for many years with great success. I don't drive my 85 911 every day (retired!) so a few months ago I started it up before a ride and it stumbled like it was on 5 cylinders. Popped in some techron and cleared up right away and has been great ever since. I was mad at myself because I'm usually up on adding it more often. Anyway, It is amazing!!!
I would think the 2200 mile road trip burned 6 tanks of gas...a guess.
Two bottles would be fine.
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
Some people say that it is a good idea to run Marine Stabil in your gas all the time if you have CIS mechanical injection, which you have. It won't hurt the seals, and it will protect the system, particularly if you are using an ethanol blend. This is the blue stuff, not the red stuff.
Techron is more for cleaning out injectors if you are having problems. Do it before an oil change, as others have said. |
RETIRED
Techron or Seafoam. BTW, SF recommends an oil change after use.
There are two products that you usually see on the shelves, The Chevron Techron and Chevron Techron Fuel Injector Cleaner. Check out the difference, I believe it is the concentration and my guess is the Porsche Bulletin refers to the higher concentration of the Chevron Techron product.
No expert just an observation.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
Banned but not out, yet..
I take a couple of shots every night before bed time. I sleep like a baby but farts can be hazardous.
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 07-31-2016 at 08:45 AM.. |
Got a box of 12 bottles at Costco recently. I've used 2 bottles now with good results, noticeably better & smoother running, power & acceleration.
Frank 1989 911 Carrera Targa 3.2L, all stock 78k miles (as of Dec 2023) "The Machine" |
Diss Member
As a suggestion...
Just use Chevron gas and never worry about it.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
The chevron "fuel injector cleaner with Techron" they sell at Costco doesn't contain much Techron in it. You want the Techron concentrate sold in a similar looking bottle at WalMart or a FLAPS. It's a good bit more expensive, but watch the FLAPS ads...they often have good sales on it.
Chevron Techron Concentrate Plus, 10 oz - Walmart.com |
RETIRED
Spam and eggs and doesn't have much spam in it either....
