procan's Avatar
DIY budget fender mounted oil cooler?
I'm looking at installing a fender mounted oil cooler when I install my rebuilt 2.4L. The Elephant racing kit costs $3,200!!! Seriously? $2K of that are just oil lines! Granted, that's with their finned oil lines, which I understand with the increased surface area of the finned tubes you get increased heat dissipation yada yada yada (ya, I took heat transfer in school), but I'm not racing on a track, or driving in LA rush hour, so that's a little excessive for my needs.
I'll part with $600-$800 for the fan kit, whatever. But there has to be a cheaper solution for all the oil lines involved from the engine, up to the fender, and back. Anyone do this on the cheap?
1969 Porsche 912/911E Hotrod - Light Ivory
2003 D2 Audi S8 - Black (DD for the snow!)
1974 Porsche euro 911S Targa - Grey (Sold! Off to the Netherlands!)
Old 07-03-2016, 08:57 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil cooler.
Keep an eye out for a cooler on the used parts forum.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-03-2016, 09:21 AM
El Duderino
tirwin's Avatar
My car came with a Terbatrol oil cooler installed by a PO. I don't know what it costs today but I'm not sure they are made anymore either.
No experience with Mocal but these seem pretty similar.
British American Transfer
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-03-2016, 09:34 AM
Under the radar
Trackrash's Avatar
Good luck,
Gerry
Find someone who is parting an SC or Carrera. That's what I did. Got everything from the oil tank to the trombone for a very reasonable price.
The other option, although, I don't like it, is to run AN stuff the whole way.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-03-2016, 10:04 AM
procan's Avatar
My issue isn't with the actual fender mounted cooler + fan, I'm looking for a solution for the oil lines running from the engine to the fender and back.
Old 07-03-2016, 10:21 AM
I feel your pain on the price of an Elephant Racing cooling system. Your 2.4L engine might not need one compared to the 2.7L that runs quite a bit hotter.
There are quite a few options out there. Google Porsche Oil Cooler or words to that effect and you'll see them.
I opted for the ER system because I have a 2.7L. It's well made and they stand behind everything. I've been having trouble having my thermostat on the system open, but for the past month it's not been hot enough to get my oil up to the 190-195F that starts the thermostat to open. (I had just changed oil and know that I'll need to add a couple quarts to fill the cooler and piping.) Chuck Moreland of ER told me he'd replace the thermostat if it turned out to be faulty.
Good luck,
Tom
Old 07-03-2016, 10:57 AM
RETIRED
Joe Bob's Avatar
You can build your own lines by using braided aircraft hose. Used oil coolers are a crap shoot not knowing if the engine grenaded or not......cleaning may help but you never know. I buy my coolers from BAT Inc. Good pricing.
2012 ML350 3.0 Turbo Diesel
Old 07-03-2016, 11:12 AM
Oil lines, auxiliary thermostat, etc.
Procan,
The solution to your oil lines, etc. has been done hundred times before. So getting them piece by piece is what you need to do. First start procuring the brass oil lines running along the passenger side rocker panel, an auxiliary thermostat, two flex oil lines for the auxiliary oil cooler, the return oil line that goes under the engine (used for SSI conversion), and two more oil lines (from thermostat to oil tank and thermostat to oil return line, SSI conversion piece).
Right now, the complete pieces needed for your oil line project would cost you about $1K minimum using good used parts. Your $600 - $800 budget is not enough to buy the needed parts at the current prices of good used parts.
A good option is to look for a complete Carrera 3.2 oil lines and thermostat (from thermostat to auxiliary cooler). Then add the oil lines from engine to thermostat and thermostat to oil tank.
Tony
Old 07-03-2016, 11:15 AM
Bucketlist's Avatar
I went with the Mocal from BAT. Cost about $1K, works great no more worries about running in 100* temps.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 07-04-2016, 06:11 AM
Charles Freeborn's Avatar
Used. Try DC automotive, parts heaven or EASY.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 07-04-2016, 09:13 AM
BoxsterGT's Avatar
Porsche Crest
I have good used factory hardlines and thermostats available at realistic prices...........
I can also supply both front and rear oil hoses for Metric and AN-12.
Please email me for details.
Len at Autosportengineering dot com
Old 07-12-2016, 06:12 AM
I'm not convinced the finned lines do any good , especially as the fins fill with dirt very quickly. The dirt must have higher thermal resistance than smooth lines, and are certainly much harder to keep clean.
1982 911SC Wine Red Metallic
OMG I love this car!
Old 07-12-2016, 07:48 AM
Traffic on the drive home yesterday confirmed that I need to do this too. That kit from BAT looks great for the money.
Old 07-12-2016, 09:17 AM
This is the way to go. No need to re-invent the wheel if a later model stock set up will handle your needs.
1972 914/4 Race Car
Old 07-12-2016, 10:02 AM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
So that's how to safely ship the long oil lines...
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 07-12-2016, 11:34 AM
82 SC's Avatar
I think I will stick with my trombone cooler at those prices. Has anyone tried VW land for coolers and then get some lines made locally at a hydraulic heavy equipment service?
Oil Coolers & Accessories
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 07-12-2016, 11:43 AM
Under the radar
Trackrash's Avatar
The fittings on the VW stuff are way smaller than what you want on a 911. The tubing used is 1/2 inch in the coolers, so way less capacity. 911s use 20mm hose, equal to 7/8".
Gordon
Old 07-12-2016, 11:52 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The folks at BAT in Florida are good people to work with for sure. Good prices on braided hose and fittings
Earl's also makes a nice oil cooler https://www.anplumbing.com/extras/earls-coolers.html
Kevin L
'86 Carrera "Larry"
Old 07-12-2016, 11:58 AM
82 SC's Avatar
Thanks for the clarification Trackrash. Still learning.
1982 SC "Spooky"
Old 07-12-2016, 12:06 PM
Location: behind the redwood curtain, (humboldt county) california
Talk to Chuck...
My 74 had frightening oil temps when dad owned the car.
I noticed the huge cost of the parts and talked to chuck. He shipped a used set of late model factory lines, and I bought the 85 cooler from him and a new factory thermostat with lines from our Ghost.
I went with the factory thermostat because it fits, and most importantly it has a pressure bypass so you don't blow the cooler with cold oil pressure.
Earlier, not knowing any better, I installed a Mocal thermostat on my Ferrari 308 because the oil almost never got up to temp and it took forevvvver to hit 180. My point is that the thermostat is important, particularly so on an air cooled car. The pressure bypass is just a safety device.
I dumped the dealer installed ac and did the 85 cooler and the temps have stayed under 210.
I am an advocate or having a larger cooler, or cooling capacity than you currently think you need because if you have more than you need, you can forget about overheating, as the thermostat will do what a thermostat does on a water cooled car - it will get the "coolant" up to temp and keep it there, with enough heat shedding capacity to keep the oil out of scary temp land if you push the car in hot weather. Not saying you can do thunderhill on a 100 degree day but it is moving in a safe direction.
Old 07-13-2016, 06:39 PM
