The 9 Store
Oil in a/c compressor
How much oil goes into the a/c compressor. We are reinstalling a nippondenso compressor back into a 3.2. Thanks
All used parts sold as is.
Old 07-13-2016, 10:06 AM
Slippery Slope Victim
NY65912's Avatar
5-6 oz AFAIK
MikeČ
1985 M491
Old 07-13-2016, 04:09 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Compressor oil.
I used 8oz.
But, I also installed new barrier hoses,
and a new Pro-Cooler.
And, was advised by the source that there was no oil
in the compressor.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-13-2016, 04:20 PM
kuehl's Avatar
Assuming.....
If you are just replacing a compressor, 2-3 oz would be sufficient.
However, if you replaced other items you'd need more.
The entire system runs with 5-6 oz.
Too little oil and there is a risk of damaging the compressor.
Too much oil and the evaporator core becomes saturated and reduces
heat transfer.
If you purchased a new compressor or rebuilt compressor there could be oil
already in it, and how much is always a guess. So, you dump that oil out by removing any plates or caps on the manifold or compressor, turn the compressor with those open ports facing down over a large coffee empty clean coffee can. Turn the outer clutch hub several times in each direction, tilt the compressor nose to back back to nose until it stops dripping out. Properly dispose of the oil and can.
Then start off fresh.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 07-14-2016, 04:58 AM
French Import
zippy_gg's Avatar
So what is the best way to put oil in a new system? Insert it in the high side of the compressor?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 07-14-2016, 07:36 PM
kuehl's Avatar
An ac technician would inject it, or you could pour the oil in the empty compressor, Mount it on the engine, attach your hose lines and rotate the outer clutch hub a dozen messed
Kuehl
Old 07-14-2016, 07:45 PM
