Two week storage
Going out of town for two weeks and will be unable to drive my 1987 Targa. Should I disconnect the battery cables or do anything special for this period of inactivity ? Thanks.
I would think it would be fine for 2 weeks. I have not driven mine for 2 weeks at a time and it's always started right up after. Battery is less than 2 years old though so maybe that helps.
1989 911 Carrera 3.2, Guards Red |
Driver, not Mechanic
I've left mine for 3 weeks straight. As long as there's nothing wrong with your electrical system that would cause a drain...
Troll Hunter
Has it really come to this?
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
winter
^ indeed it has. . .
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
RETIRED
Nice Targa, sorry about that lobotomy.....
BTW, if you are worried about battery drain, buy a trickle charger. Mine is hooked up every time I park it.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
Since I have two cars I often don't get out in one of them for weeks. The 3.2 has never had starting issues and isn't plugged in, it's only the 993 that does. In the 993 there must be enough active electronics to kill the battery over a few weeks. I wouldn't doubt the 3.2 would start after months of inactivity.
![]() A month should be no problem... it isn't for mine and I can't trickle charge as there's no power where the car is stored. |
Go Speedracer, go!
Two weeks? Geez, that's nothing. I store mine for several months at a time with no activity and it always starts right up. Just keep a trickle charger on it and it will be just fine.
I think I went a little over 6 months this winter without even taking the cover off of my 911. That amount of time with no activity causes the soft rubber tires develop flat spots and make the first few miles of driving like a vibrating bed at an old motel. 10 miles in though and they get enough heat into them to round out.
1981 SC ROW Coupe |
Go Speedracer, go!
These things are great. I have 3 of them for my cars. Funny story, I always used to put the Battery Tender right in front of the front wheel when the car was being stored up on the lift. My thought was that I would see it as I was lowering the car and remember to unplug it before driving the car. Well that didn't work and I accidently drove over the Battery Tender. It flattened it almost like a pancake, but it still works!!! I took it apart and straightened it out a little bit, that was only for aesthetics. Tough little device.
1981 SC ROW Coupe |
Fleabit peanut monkey
Another thought is to buy a $15 bayonet type disconnect for the negative post. Pop the hood, lift the blade. Worries are over. Especially good if you have a slight parasitic draw.
1981 911SC Targa |
