964 heat exchangers fit on a 3.2 engine?
Sorry for the simplicity, I could not find a quick answer for this....
I found some 964 heat exchangers. I wondering if they will fit on to a 1985 3.2 engine
Thanks In Advance!
Old 07-28-2016, 08:05 AM
Member 911 Anonymous
DRACO A5OG's Avatar
From looks of the PAG diagram, I don't think it will without some modifications.
'85 Carrera Targa
PCA/POC
Old 07-28-2016, 09:57 AM
Thanks In Advance!
Won't work! They will bolt up OK but will interfere with the 915 trans clutch arm assembly when you try to bolt a 915 tranny to the motor . When I did a 3.6 transplant into a '82SC back in '92, the first thing I needed to do was replace the
3.6 HEs with Carrera HEs.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 07-28-2016, 11:43 AM
Gracias
Old 07-28-2016, 11:55 AM
RETIRED
Joe Bob's Avatar
993s will work IF you re index the flanges on one side. They aren't getting any cheaper though. But cheaper than the Dansk made SSIs. So pick your poison.
2012 ML350 3.0 Turbo Diesel
Old 07-28-2016, 03:08 PM
