Blackbyrd's Avatar
83 SC @ frame bench need specifications
Looking for specifications of the chassis for an 83 SC
I have some for an SC PRE 81 and 84+ CARRERA. But want to make sure I have the correct dimensions and compare them.
Any one have copies of the pages from the books
Something I can print for the shop
Not looking for the 70s or late 80s need exact 81-83 SC specific dimensions/measurements
Coupe !
Follow me on Instagram: efrenporsche
Old 07-30-2016, 11:16 PM
Mark Salvetti's Avatar
Are you sure they are different? My factory manual seems to be current through 1983 (it includes pages for the 1983SC, but I bought it used around 1990, so it might be missing some supplements).
Anyway, there are only two pages with frame dimensions. This first one says it is good for 1972-on:
And then there is this one with the companion dimensions page. The two drawings only have a few common measurement points, but where I checked the overall dimensions were the same, only the allowable tolerances in the second set are slightly greater (by 0.5mm or so):
You can download full resolution images (including a couple of the first page that can be taped together to show the entire image) here: Workshop Manual Scans
Mark
1979 911SC Targa
Old 07-31-2016, 09:30 AM
walt's Avatar
I have a technical specification book for model years 82 and 83. Verified numbers in the table above are the same.
Walt
Walt
82SC 3.0
81SC 3.6
Old 07-31-2016, 10:19 AM
