Using Timing Light on Twin Plug Engine?
I need to check the timing on a twin plug 3.0 engine. Do I just connect it to number 1 spark plug cable as I would for a stock single plug engine? Can I use my timing advance knob on the timing light or will the readings be off for a twin plug engine?
Old 08-04-2016, 09:10 AM
Use #1 plug just like on a single-ignition engine.
Time the car just like you would with your dial-back timing light, but bear in mind the differences in timing values.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-04-2016, 10:28 AM
Thanks Steve. What do you mean by "differences in timing values"?
Old 08-04-2016, 10:30 AM
T77911S's Avatar
less advance is needed with dual plug
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-04-2016, 11:37 AM
rsscotty's Avatar
I think what Steve is referring to is that you don't use the single plug timing numbers on a twin plug engine.
Old 08-04-2016, 11:39 AM
Could you elaborate.........
Steve,
Could you elaborate more on this subject? Thanks.
Tony
Old 08-04-2016, 12:05 PM
Eva
911SauCy's Avatar
IIRC, A single plug 3.0 engine idles 5deg before TDC and advances to 25 deg at 6000rpm.
Because a twin plug is more efficient at burning the fuel charge there will be less timing advance required to get the power out of it.
I just don't personally know what the numbers are.
Someone chime in with those deets!?
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 08-04-2016, 01:46 PM
Yes. Would be great to know the timing numbers for a twin plug 3.0.
Old 08-04-2016, 08:45 PM
