You would put these in the 3.2 conversion or in the standard 3.0?
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
I do agree that the SSI exchange the heat better then the standard Dansk stuff Porsche used.
They are available in both bore sizes. A 3.2 is a later 3.2 (carrera) engine A 3.2 conversion is an earlier 3.0 converted to a 3.2 (short stroke) engine Commonly referred to as simply a 3.2ss (versus the later 3.2 which has a longer stroke) So if you have a 3.0, and you want more displacement, go to a 3.2ss, and chose whatever compression pistons you would like at that size
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 08-12-2016 at 11:52 AM.. |
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
This is very true and why they were created. The original owner of SSI got sick and tired of patching the early heat exchangers he installed on his SC.
One thing to consider for the OP. What are your emissions laws where you live? You need to investigate what any planned mods will do to the legality of your car. |
Sc engine upgrade
I have an 81 SC and I'm rebuilding the engine right now. I'm backdating the exhaust
to 74 which will give me 10 hp. Boat tailing the crank is good for 10 hp. I'm removing the cis and installing 40mm webers for another 10 hp. 3.2 cylinders with 22 mm wrist pins and different pistons and a 911S cams with a 78 dizzy with a recurve and I'm looking at 300 hp and a flat torque curve |
Do you think 300hp is achievable with 40IDA carbs? - it seems a bit optimistic.
I am not sure about what problems will occur due to running a higher compression with a 'softer' cam such as a 964. Plug shrouding due to a high domed piston is a much bigger problem with the 2.0 litre where increasing compression much beyond 10.5 tends to reduce low end performance. 2.0 litre single plug race engine don't seem to get much beyond 200 hp and have poor low end performance. The shallower chamber used in later engines is a little more forgiving and at 10.5:1 works quite well without twin plugs. It would be good to compare single plug 9.5:1 and 10.5:1 engines to see what happens to the Torque behavior. The pin offset is also interesting and I would be keen to find a table of different pin offsets with regard to bore and stroke combinations. If I have understood correctly an offset pin will reduce the inertia loading regardless of the direction of the offset. The thrust, however, will be different from side to side depending on the direction of the offset. I guess most piston manufacturers believe that the inertia loading has the most importance as the thrust will change depending on which side of the engine is considered. As far as I know none of the 911 pistons are 'handed' and I wonder if this is worth considering? |
Thanks to everyone for suggestions and idea's.
I think i would like to go for the following set-up correct me if you see anything off: On the original case to 3.2 with the use of 98mm pistons. No 964 cam, standard SC cam retained. Stock CIS retained. On the pistons I understand I have the choice between JE and Carillo? Are the standard SC con rods re-usable on this setup? I read on one of the posts an issue witht the pin? What about compression? 9.5? On the exhaust most likely SSI mated to a muffler 2 in 2 out. What would this set-up run in the US money wise (labor plus parts) Ball park figure ofcourse. Michel
Ok, Here's mine.
Euro 204 BHP Standard 3.0 P&Cs Standard CIS 964 cams SSIs Classic Retrofit CDI+ ignition. This dyno run was against a standard low mileage (65K) SC which made 199 BHP on this dyno. Green - standard SC Orange - The same standard SC with CDI+ ignition (no ignition timing changes) Blue - My SC as per above spec plus a little extra ignition advance. I asked my builder to time the 964 cams for low down power. High RPM power doesn't deliver the fun IMO. It turned out just how I wanted. A whole thick wedge of extra torque added where you feel it most.
www.classicretrofit.com |
Other than the SSI and custom muffler, the piston increase and cylinder boring will add"only" a grand or so for pistons but up to and additional 3 grand or so for new cylinders or reboring and plating the old ones?? So, just go 9.5:1 pistons (assuming your bores are good) and its a little over a grand more Or goes up to a 3.2 with pistons and cylinders for about 4grand more $US (or almost $7 grand for Mahle) (the real big money is in gaskets and labour it seems. These engines take a lot of labour).
Deals can be had if your not in a hurry, diligently watch the classifieds, and be ready to pounce when what you need pops up for sale.
Eva
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Lots of talk here.
Am I really the only modified SC owner here who can post an actual dyno plot?
![]() 3.2ss (EBS 98mm bore cylinders, JE 9.5:1 98mm pistons), 964 camshafts, re-curved WUR, 4R CIS intake manifold.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
If that is at the wheels, that's an impressive torque peak. Nice and flat too.
Vereeken, I'm an SC owner from Belgium as well
Who will do your engine build? Everything or will/can you assist? I'll be following your adventure closely (Will you create a thread on PP?) as I'm looking to have my engine rebuilt in the coming years as well and was asking myself the same questions! |
