911 SC engine upgrade. What would you do?
Yes I know how to search but I do not want to trawl through 1.000 pages
![]() I am hoping to get some pointers as to the different paths to take. My SC decided yesterday to succumb to the head stud problem. I had planned for this to happen around October, but he had other plans. So off it is for an engine rework. The engine is just fine, no oil usage to speak off good power, etc.... I am in no need for a race monster. This is a street only car that I enjoy for the looks and the nostalgia. What would you do to the engine? Is there an easy way to extract some extra power? Would you go for 964 cams? Would you work on the exhaust side? Or is it all not worth it ans simply rework to standard.
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
depends on if you need P&C's and what type you have. then I would break it down into 2 categories, one with new PC's and one with old ones. then I would break it down again as far as what induction system you want to go with. carbs, EFI or CIS,
Old p&c and I do not want carbs. I have no issue with CIS but understand it is limited performance wise.
Make it a 3.2 with stock cams and CIS.
You will be VERY pleased.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
sell it and get a 3.2.
Tru6 Restoration & Design |
I think that when it comes to Cams, CIS is the limiting factory is it not?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
964 Cams, (assume you already have Euro SC Pistons?) have the dizzy rebuilt and re-curved, tweak the CIS a little to get good A/F. Done
Gary R. |
I am not going to get a Carrera. i drive a SuperCarrera ;o)
Yes indeed; this is a euro car with 204hp (actually 213 on the dyno) Can you start from the 3.0 casing to move to a 3.2? When done are there any evident visual clues?
Under the radar
If money was no object. 98 mm P&C, 964 cams, Carrera crank and rod set. Would make a 3,4 and look stock on the outside.
Moved to #1 spot.
Speak to William Knight!
Home of the Whopper
Change cams, early exhaust and verify throttle linkage is properly adjusted.
The wave is not the water. The water merely told us about the wave moving by Buckminster Fuller |
Actually put some equal length headers (no heat) on her if you don't drive in winter!
Gary R. |
Coram Deo
I did 964 cams and SSIs, hollowed out muffler, heat backdate and A/C removal. My goal was more responsiveness (less weight, more power). Next round, I hope to go with ITBs and electronic injection / ignition for the same reasons. I'm not ever going to be a racer, but driving my Targa will always be an event. Will return 6 empty cases to Malmedy this weekend. May pick up 6 full ones!
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
SC Upgrade
If you are finding yourself in a very similar boat as I was in 2 years ago when my numbers matching engine in my MY74 911 coupe suffered with pulled head studs, then I would follow the same course of action as I underwent:
Obtain low mileage SC for rebuild Add ARP Head Studs Add ARP Rod Bolts Add Titanium Valve Springs Use High-Flow CIS Add Carrera Chain Tensioner upgrade Add real 964 Cams The 3.2L engine will have more HP, and more top-end, but lacks the peppy punch you will find in a 3.0L. Add that you will probably want a Motronic engine management system on the 3.2L that will add better fuel reliability, while adding complexity. The 3.0L from an SC 911, when you use an early 70's era SSI setup that goes into a dual in dual out muffler, coupled with a short ring and pinion set 915, and you have one hell of a ride! Trust me as I know firsthand.
Ryan Russell (405) 264-6288 |
Platinum Member
If it's an original car with matching numbers, I would put the engine on a shelf and find a 3.2
Yes, its called a short stroke 3.2 (done with displacement)
vs the factory long stroke 3.2 (done with different crank)
This was the route I am heading with an '80 RoW big port with Mahle 98mm wedge (Max Moritz style) pistons.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Fleabit peanut monkey
Just food for thought and just talking. My 81 had the head mating ring surface re-faced with a six thousandths of an inch reduction. I did the math, posted calcs here years ago and it was confirmed. CR went from 9.3:1 to 9.5:1. A mini bump. I would be amazed if it was over a couple of HP increase, but don't know. What I also don't know is if a 9:8:1 to 10:1 mini bump pushes you into a step change scenario that requires all kinds of tending to, given gasoline octane obscurities I know nothing about.
1981 911SC Targa |
