NEWFIE 69 911E's Avatar
Cylinder Review please
Hi all,
Recently dropped engine in my 1980 911SC RoW Targa with 200K Kilometers due to broken lower head studs. Engine is now dissembled, and heads will require minor polish / flycut. My plan is to leave the crankcase and P&Cs alone, due to low mileage and excellent operation before the stud issue(s) + my low annual mileage history (20K KM in 8 years)
All but one cylinder have no scoring, but #5 has one minor score:
How does it look to cylinder experts out there? Thanks
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 08-06-2016, 11:15 AM
If that is all of it for that cylinder I think that you are ok by still using it.
Old 08-06-2016, 04:04 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Prior to disassembly, did you do a compression and /or leak down test?
'85 Carrera Targa
PCA/POC
Old 08-06-2016, 04:21 PM
Thanks for reply, I am thinking the same
1969 911E Coupe
Old 08-06-2016, 05:11 PM
No, I did not
I know I should have, but did not have the equipment for leak-down, and was not sure that compression readings would be legit with so many broken head-studs.
My bad
1969 911E Coupe
Old 08-06-2016, 05:14 PM
DRACO A5OG's Avatar
I would post on the engine rebuild section, they may know more but I agree that cylinder looks fine.
When you put your finger nail on it, can you actually feel the groove?
'85 Carrera Targa
PCA/POC
Old 08-06-2016, 05:33 PM
Thanks. Yes, I did post on the engine forum but no replies yet.
Yes, you can feel the groove, but just barely, if that makes any sense!
Old 08-06-2016, 06:24 PM
That scratch could be from a broken ring.
200,000 kilometers? Never rebuilt before? 40 year old seals.
Now is the time to dig a little deeper if you plan to keep the car.
Old 08-07-2016, 12:41 AM
GaryR's Avatar
Send a message via ICQ to GaryR
I agree, I would absolutely be splitting that case, replacing all bearings, seals, timing chains and ramps, etc...
Gary R.
Old 08-07-2016, 07:01 AM
Many thanks for advice,
According to Wayne's book, and other posts here, the crankshaft etc should be ok for another 200K KM (not miles), so I am inclined to leave the case alone, except for replacing seals and chain ramps.
Old 08-07-2016, 09:04 AM
Engine rebuilding......
Since this is your first engine rebuild, I understand your apprehension about doing a top and bottom rebuild. I did the same for my very first one too. It is a decision you have to make yourself. But after several engine rebuilds, the additional bottom rebuild work should be included because it does not take much time to do it. It feels very intimidating when you have not done one before. Once you done one, you will understand why people encouraged you to do the top and bottom rebuild even with a 200Km.
Tony
Old 08-07-2016, 10:29 AM
Originally Posted by boyt911sc View Post
Since this is your first engine rebuild, I understand your apprehension about doing a top and bottom rebuild. I did the same for my very first one too. It is a decision you have to make yourself. But after several engine rebuilds, the additional bottom rebuild work should be included because it does not take much time to do it. It feels very intimidating when you have not done one before. Once you done one, you will understand why people encouraged you to do the top and bottom rebuild even with a 200K miles.
Tony
Thanks Tony,
Please note engine/car has ~200K kilometres = ~ 124K miles , and the engine has not been opened before.
Re top-end: I will send the heads to a machinist experienced with Porsche air-cooled here in Canada for inspection and assessment.
Re bottom-end: I will think it over and decide; in the meantime, what do you think of the cylinder as noted above?
Best,
Tom
1969 911E Coupe
Old 08-07-2016, 11:11 AM
Nine9six's Avatar
Thanks Tony,
Best,
Tom
Exactly! I wouldnt touch the very robust bottom end that can typically go 250-300k mi. So 124k is basically half-life.
Leakdown test is gennerally performed to che..ck valve seal integrity. Compression test for cylinder compression check.
Generally speaking, if you can hang your fingernail on the groove, its .003-.005" deep. Cleaning up cylinders with a hone certainly wouldn't hurt overall compression...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 08-07-2016, 12:27 PM
Thanks - we agree re half-life
Only one cylinder (#5, above) has a score, and cross-hatch pattwrn is still seen in all cylinders.
Not sure I can hone these cylinders; they look like Alusil to me...
Happy motoring!
Old 08-07-2016, 01:06 PM
Hi thread followers
Ok, for peace of mind , I decided to pull the piston out. Happy to find no broken rings. Still wondering, what could be the cause of this score? You can see a corresponding mark on the piston skirt...
Old 08-19-2016, 05:28 AM
Discseven's Avatar
Newf... Suggest measuring cylinders for taper and ovality (according to Porsche specs.) Cylinders can look fine to the eye but if our of round, performance is lost.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-19-2016, 06:35 AM
