wprater's Avatar
PMO Torque Specs?
Looking for a comprehensive list of torque specs for the PMO carbs. As if I were going to rebuild them.
Would these be the same to a Weber? Or is there a list for this?
Currently Im looking for the following:
- Fuel rail bolts and barb connectors
- Intake manifold to heads
- Intake manifold to PMO body (8-10 ft. lbs.)
- Body top cover
- Top cover horns or rain tin
- Linkage brackets to body
Any ideas?
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 08-24-2016, 06:26 PM
al lkosmal's Avatar
Greetings.............I've never seen these specs. If you really need these values.....your best bet is to contact Richard Parr at PMO and ask him.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 08-24-2016, 06:50 PM
moneymanager's Avatar
I just tighten them tight! I've never had a problem. It helps to go back over them a month or two later as gaskets will slowly compress. .
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 08-25-2016, 06:58 AM
