Is this Alternator noise normal?
Hi. I took my fan belt off as it was squealing and needs tightening.
I was checking for bearing play on the fan and it seems really good, no movement.
Spinning the fan I get the noise in the video, not sure if that's normal or not, just the brushes on the rotor arm??
From the service history its been rebuilt before, probably about 40k miles ago.
Gives a good charge.
Thoughts?
Tempted to put it back on, tighten belt and off I go. You might need to turn volume up....
https://www.youtube.com/watch?v=eJy7rcK3SQg
Ed
Old 08-29-2016, 01:37 AM
T77911S's Avatar
no
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-29-2016, 03:39 AM
76 911S Targa
This is not a normal sound. You need to diagnose the problem. First, look for any places where the fan may be touching the fan housing or perhaps some debris has been caught in the assembly. This sounds a lot like fan scraping to me. Perhaps your fan housing is overly tight which can deform the fan housing from being perfectly round. If that is ruled out, remove the alternator/fan assembly and check the alternator for faults. Either a bad alternator bearing or possibly brushes worn to the holders would be sources of this noise.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 08-29-2016, 08:44 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+3, not normal
Could be just the vr worn down
Remove and post pic of brushes
'85 Carrera Targa
PCA/POC
Old 08-29-2016, 09:32 AM
If it's a Bosch the regulator is bad and is easily changeable. Happens on ALFA's all the time. Got 4 spares 2 bolts and a plug done. It's part of the alternator. Unfortunately in the ALFA I have to take it out to repair it.
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 08-29-2016, 10:38 AM
Which is the preferred VR I should be looking at? PP has a number of them.
Thank you.
Ed
Old 08-29-2016, 01:28 PM
76 911S Targa
Don't buy parts until you have a diagnosis.
Old 08-29-2016, 01:32 PM
Alternator to be removed ce soir.
Old 08-29-2016, 04:12 PM
DRACO A5OG's Avatar
^^^ +1, always.
'85 Carrera Targa
PCA/POC
Old 08-29-2016, 04:14 PM
Keep us posted. I discovered the exact same issue when I replaced my fan belt.
Old 08-30-2016, 05:57 AM
theiceman's Avatar
that sounds like the bearings are beat and the fan is catching the shroud. if so an easy fix for an alt shop .
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-30-2016, 06:14 AM
I took everything apart last night. An entertaining but rewarding job.
I am 100% sure the noise is the front bearing so the plan is to take it to an alt shop for rebuild. I was considering doing it myself as the VR is external. However I dont have the right tools to get the bearings off.
The front bearing is obviously worn as the fan has a big section missing so its off balance.
The VR 'looks' ok but the brushes are different heights, not sure why. I will take advice from A shop on replacement or not. I cant tell if the VR is made by a reputable company or just some cheap rubbish.
New fan needed. :-( In addition to the bit missing, it has several cracks and dings. Its in poor shape. The shroud is good.
Old 08-30-2016, 09:29 PM
DRACO A5OG's Avatar
Nice Diagnosis, So bearings were noisy off the car as well? My brushes were allot worse.
'85 Carrera Targa
PCA/POC
Old 08-30-2016, 10:25 PM
The noise seemed to be coming from the front, and where the front bearing sits. I thought it was the VR brushes at first, but with the external VR removed, it made the same noise.
Are there any more brushes internal to the alternator? Sorry if thats a stupid question, but Im thinking as I have the external VR, the brushes are on that and not internal to the alt.???
The alternator spins creating a charge, the VR picks up that charge via those two brushes and distributes to battery etc.
Opposite to an electric motor where the brushes transfer the power to the coil to make it turn.
Never really thought of it that way before.
Homer Simpson noises.
Old 08-30-2016, 11:03 PM
How do I split the ALTERNATOR open? I have removed the through bolts, is there anything else?
Tks
Old 08-31-2016, 05:03 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Alternator.
Identify this sound...
Here you go.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-31-2016, 06:46 PM
sugarwood's Avatar
Fan for $369
Porsche 911- 11 Blade Alternator Fan - Aluminum: Engine Cooling &amp Fans Related Parts
1986 Bosch Icon Wipers coupe.
Old 08-31-2016, 07:01 PM
Nice, a classic "Crownee".
I have looked through your thread and as much as I like DIY, I think it will be quicker for me to drop alternator off at local shop. I was considering doing it myself but path of least resistance is to shop it while I get on with cleaning everything else. One of my fan blades is also cracked. I am going to attempt to balance using a cheap motorcycle tyre balancer I have. Replacement cost of fan here is a lot, esp with shipping. I will advise how I go.
Old 08-31-2016, 07:12 PM
Thanks Sugar wood.
However with shipping, and currency conversion, that equates to nearly $500 of my hard earned ozzie dollars. Plus I will have to wait three weeks for it to arrive. There are some on evil bay for a few bucks cheaper. Im going to attempt a fan balance as per above. She'll be right.
Old 08-31-2016, 07:37 PM
DRACO A5OG's Avatar
Make sure take your pulley half and nut with you, they may not have one to test the alternator after refurb. Tell them not to hammer the alternator out.
'85 Carrera Targa
PCA/POC
Old 08-31-2016, 10:11 PM
