I have an 86 915 gear box that was rebuilt by a local shop. I didn't install it until a couple of years later, so it's out of warranty. Sometimes shifting from 2nd to 3rd, it will not go into 3rd. I have to shift back to neutral, move shifter to the left (1st,2nd plane) and then try again. Usually doing this once or twice and I can get it into 3rd. Sometimes it goes right into 3rd without this ritual. Any idea what might cause this?
I have tried a Rennshift and stock shifter with the same issue.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
Sounds like your coupler is out of adjustment
Ernie |
Registered Minimalist
2nd for coupler is either toast or needs adjustment. Take a look under the panel behind the seats.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Reiver
How many miles on the rebuild....I had a similar balking issue on a rebuild that went away once 'broken in'...you are probably mixing new/old and it takes a bit to bed in. Mine was a second gear deal.
I would check the adjustment as advised too.
De Oppresso Liber Strength and Honor 5th Legion |
Only a couple thousand miles since the rebuild. It's a 915/916 914 setup with a 3.2. So there is no coupler. Just an adjuster under the center console that allows me to make adjustments. I tried every possible adjustment and the issue is still there. To much one way and I lose 5th and reverse. Too much the other way and I lose 1st and 2nd. Otherwise I can get into all the gears, with the way it's adjusted now.
I had the same issue on my 915. It turned out to be the internal selector forks had not been set correctly. I found the issue after I rebuilt the box myself after a previous rebuild a few years ago.
On my box there was insufficient separation between the two selector forks so essentially I was trying to engage two gears at once. With correct adjustment this issues is completely fixed. I also spent much time adjusting the shaft coupler thinking it was this...... See this thread: having trouble adjusting shift forks in 915 transmission. |
Targa, Panamera Turbo
/\ this - I had the same issue, changing the coupler eliminated it.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
There is no coupler on this car.
72 911 Although it is done at the moment, it will never be finished. |
Thanks everyone for the help!! At the firewall i'm running the PMS shift rod bearing. A pretty precision setup, but has no slack.
914 Gear Shift Rod Bearing Kit - (1970-1976) PORSCHE 914-6/4 - Fire Wall / Bulk Head By Patrick Motorsports Porsche & Mid Engine Performance Specialists I thought about removing it just to see if it would help. I'm leaning towards SUB8's conclusion, since I have no coupler and have fooled around with the side to side and fore and aft settings, to no avail.
