Have a look at the CIS training booklet that accompanied the addition of the O2 sensor in 1980. I don't have a copy, or I would send it to you. Someone here probably has one.
JR |
Crotchety Old Bastard
The -129 WUR was the Bosch replacement for the defunct -009.
Standard WUR for '73.5 was the -001, standard FD was -004. If you have these units and the small runners that go with that system it will never work properly on your 3.0L engine. I have seen entire 3.0L Euro CIS systems for a few hundred dollars here in the classifieds, that is what I would do if in your situation. Here is some information on Porsche 911 CIS if interested: Porche Enthusiasts Page
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Just wondering if anyone had any thoughts on it. Will check the manuals. |
Another option to consider is to install a programable WUR from Unwired Tools: www.unwiredtools.com.
When I rebuilt my early 2.7 ltr CIS motor to 2.9 ltrs, but kept the original early 001 WUR that is not adjustable, the motor was running way too lean thru the entire power band. Installing this unit that was programmed to run much richer solved all my annoying hesitation on acceleration and detonation issues. Best $600 I ever spent! |
JR |
A quick update:
Took the car to the track yesterday and observed a few things: • When in stop-n-go traffic, the AFR numbers were on the lean side, mid 15s • After a bit of cruising, the AFR numbers leveled out to the low 14s • At the track, once the car was warmed up, WOT was well into the 13s I was concerned a bit about those lean numbers when in stop-n-go traffic, but it seems like once the engine is hot (/warmed up/?) and at cruise that the numbers all come down into the 14s.
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
My suggestion is still to learn more about which components you have and, if much of the system is from a '73, swap it all in favor of a 78/79 US or any ROW system. The car will never run as well as it should with what you have now.
JR |
There's a complete system off of a '80 ROW ar for sale in the classifieds right now. Been for sale for a while, you you might be able to make a good deal on it. The seller's user ID is charwood77.
JR |
