cis airplate question
question about 79 sc that's running rich strong exhaust smell. so I open the airbox while engine was running and push up on the level plate and the engine started running smoothly but a little high idle. long story short. pushing up on the level is richening are lean. I know how to adjust with the alley wrench .. but I'm a little confused about the level thing. thank you very much.
sylvester
Old 09-01-2016, 12:43 PM
After I renewed my CIS and got it started, I though I was running rich too because of the strong fuel smell out of the exhaust, I bought a LM-1 and did an actual test and I was super lean!
I wonder if it is too lean, maybe the fuel doesn't completely burn?
Rutager West
Old 09-01-2016, 01:09 PM
OK.... I will check the plugs tomorrow and report back thank you.
sylvester
Old 09-01-2016, 06:53 PM
Air plate moving up under constant throttle enrichens the mixture. (More plate rise equals more fuel flow.)
Old 09-01-2016, 08:46 PM
OK.. thank you sir
sylvester
Old 09-01-2016, 09:03 PM
Functionista
manbridge 74's Avatar
Wonder no longer. Incomplete combustion indicated by high hydrocarbon levels is because it's lean. Richening mixture makes HC level go DOWN. I used to set cars up to pass emissions when our county had emission screenings.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-01-2016, 09:16 PM
