Windshield install help needed still water
Hi guys
Installed a new windshield seal on my late 89 930 ( same as 964 seal) the corners were not sealing to well so I replaced it with an original porsche one. A little better but still seams to small and water gets in
I was told to use a 3m bedding compound.
Do you guys use this stuff and how do you use it?
Old 09-03-2016, 02:35 PM
I've used the 3M product on all my installs. I shot it under the lip and into the corners and the corners took a bit. I then used a block of wood and mallet to drive the seal in the corners. worked like a charm.
Old 09-03-2016, 02:49 PM
