procedure for clutch cable adjustment 915
Hi,
I have some problems adjusting the clutch cable on a 1982 3.0 SC 911 (Targa).
I did follow the guidelines as described in Wayne Dempsey's handbook, but still no luck.
See picture: I did the adjustment with the spring turned to the right side (near heatexchanger). So far so good. But when I engage the clutch pedal afterwards, it will never go back to that right position. Also, the clearance of 1 mm is completely changed. Thanks for some help/guidelines
bas
Old 09-04-2016, 02:08 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You have to do this several times to compensate for slop on the TOB to Fork, if worn.
'85 Carrera Targa
PCA/POC
Old 09-04-2016, 02:33 PM
pete3799's Avatar
Is this just an adjustment or have you replaced any parts. Cable for instance?
Just to be clear the 1.2mm adjustment is made with the bolt and lock nut. The 1mm adjustment is made with the 2 nuts on the clutch cable as seen in this picture
Pete
79 911SC RoW
Old 09-04-2016, 02:44 PM
DRACO A5OG's Avatar
^^^, wow you can eat off that gear box WOw
'85 Carrera Targa
PCA/POC
Old 09-04-2016, 02:58 PM
pete3799's Avatar
Wish it was mine.....stole the picture somewhere.
Pete
79 911SC RoW
Old 09-04-2016, 03:40 PM
DRACO A5OG's Avatar
LOL. But still so clean, mine would only last an hour like that
'85 Carrera Targa
PCA/POC
Old 09-04-2016, 04:07 PM
Uncertifiable!!!
Uwon's Avatar
Also, make sure that the cable sheath is properly seated at the back wall of the tunnel. Been there myself.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 09-05-2016, 06:48 PM
Hi,
Thanks all of you. I executed the procedure a couple of times. Apparently, things need to 'find their way' a bit. 3rd time it succeeded.
Bas
Old 09-06-2016, 03:20 AM
DRACO A5OG's Avatar
Outstanding! After 100 miles or so, check again. Just to make sure all is good.
'85 Carrera Targa
PCA/POC
Old 09-06-2016, 08:54 AM
Hi,
Still no luck ... I thought I adjusted it ok. The procedure 1.2mm (loose cable) and 1 mm (cable attached, nuts adjusted) is OK, but the travel range is not ok. It should be 25 +/-0.5mm but it appears to be something like 23mm . I did not find anything beneath the wooden plate (where the pedals are). The clutch pedal is completely kicked down - I can't physically press it furter to increase the range...
Any advice?
thanks in advance
Bas
Old 09-12-2016, 11:55 AM
Peter Zimmermann's Avatar
See posts #6 & 7; replacing clutch cable any pointers?
These might have some helpful info for you...
Keep the Shiny Side UP!
Pete Z.
Old 09-12-2016, 12:50 PM
DRACO A5OG's Avatar
Post a pic of your foot board
Should be like this
Originally Posted by BasRottier View Post
Hi,
Any advice?
thanks in advance
Bas
'85 Carrera Targa
PCA/POC
Old 09-12-2016, 12:58 PM
Possibly a cracked release fork. I struggled to adjust my clutch until my fork let go. New fork and now a clutch adjustment is easy and holds.
Old 09-12-2016, 02:21 PM
^^^Yep, chances are very good that the OPs problem is either, 1) internal at the clutch, or 2) at the pedal assembly.
Pete Z.
Old 09-12-2016, 03:14 PM
I just did this job a few weeks ago and also couldn't get the right final set up. After reading many threads I saw that a new cable install sometimes is set too long and the proposed distance at the clevis needs to be shortened. If there is a new cable involved I would look into this. Once I did this everything worked great. Final travel adjustment at the floorboard was needed too.
Good luck
84 911 Targa Carrera currently getting renewed
Old 09-12-2016, 08:39 PM
Uncertifiable!!!
Uwon's Avatar
Hi,
Any advice?
thanks in advance
Bas
23 mm won't do-been there myself. The fine pedal travel adjustment is achieved by moving the small plate with rubber stopper on the BACKSIDE of the wooden floor board. Look at DRACO's pic above and you will note two screws that hold the adjustment plate.it slides up and down diagonally to give you that final adjustment. If you cannot achieve 25mm then adjust the clevis at the front of the tunnel or it's a bent fork.
Good luck.
Johan
Old 09-13-2016, 04:30 AM
Uncertifiable!!!
Uwon's Avatar
bas, you may want to look at my own trials and tribulations in my thread
Clutch Suddenly Gave Up
particularly Jeff's posts (manridge 74) numbers 35 and 36.
Keep us posted and good luck.
Johan
Old 09-13-2016, 07:23 PM
